Amlogic Next7P12-8G Modified Recovery - Stock Rom & Flashable Root
Originally posted by shaunmt View PostCWM seems to be working perfectly, including the nandroid backup and restore functions. I think the version I compiled even includes a mod that is supposed to map bad nand blocks during formatting so that they get skipped.
I may start posting CWM as early as tonight... but I'm going to have to make versions for each tablet model. I thought I could do a generic amlogic one, but I'm afraid bootloader, kernel and partition size variations between models may lead to problems.
I'm also so extremely close to finishing CM10 that I'd like to get everything working on it, in case I need to change any of the recovery code to make it work correctly.
ShaunMT
Good news?
Originally posted by Eugene_V View PostHi Shaun
Good news?
ShaunMTFreaktab Rom Developer
Originally posted by jmoreira1701 View PostAfter performing this procedure does not work on my tablet wifi
What can I do???
This is often an issue caused by a bad install. It can almost always be resolved by wiping data and cache from recovery, or by reinstalling the ROM, however it can be very frustrating, as it often requires wiping or flashing more than once to fix. I'm pretty sure these cheap tablets have even cheaper nand memory chips that get bad blocks in them.
Here are some suggestions.
Reboot to recovery.
Wipe data and cache. Do it twice each before rebooting.
If that didn't work...
Reformat your external SD card.
Redownload the ROM and the modified recovery.
Put the new files on your SD card.
Reboot to recovery.
Wipe data and cache. Do it twice each.
Flash the ROM again then reboot.
If that didn't fix it, just keep trying.
Originally posted by shaunmt View PostWhat is the manufacture date of your tablet?
Reboot to recovery.
Reboot to recovery.
ShaunMT
Originally posted by not1ofthepack View PostI think the problem is with the "YFG" 2013 tablets
The only ROM dump I have for the Next7P12-8G is dated 10-23-12 in the build.prop file.
Anyone got anything newer in their build.prop?
[QUOTE=shaunmt;132065]Possibly, that's why I asked for your date. We recently discovered that the internal hardware components of the Next8HD8G changed during late 2013.
ShaunMT[/QUOTE
The good news is the modded E3 recovery works on the newer build.
Originally posted by shaunmt View PostPossibly, that's why I asked for your date. We recently discovered that the internal hardware components of the Next8HD8G changed during late 2013.
ShaunMT
Originally posted by danstns View PostI have a Next7P12-8g YFG0713127412 Build #IMM761.v005 rooted. I ve been following your post. Im a Noob at all this so not sure how to send a rom dump or how to do a rom dump. So maybe I wouldn t be to much help.
Originally posted by danstns View Postro build date
Tue Jun 18 14:31:16 cst 2013
Here are the dump instructions:
http://www.freaktab.com/showthread.php?7768-How-To-Dump-The-Stock-ROM-from-an-Amlogic-Based-Nextbook-TabletFreaktab Rom Developer
There are currently 2955 users online. 0 members and 2955 guests.
