Amlogic Next7P12-8G Modified Recovery - Stock Rom & Flashable Root
    U rock Shaun we all thank u for ur hard work, i myself will wait, cause u do good shit, and i know we all appreciate it, thank u shaunmt
    Pantera
    [Revolution is my name]
      Originally posted by shaunmt View Post
      This is just a new recovery. The next release will address wifi issues and more. Trying to finish it between work, school, family, etc...
      ShaunMT
      So what you're saying is that post was nothing more than a cruel tease.
      Got stuck in a boot loop and used the other release knowing the WiFi was I 50/50 gamble. I lost. .. but at least it worked perfectly otherwise
        Sort of... but the reason I knocked out the TWRP releases was so that there would be a custom recovery available for installing the new customized Next7P12-8G ROMs that ARE coming NEXT.
        I've got just a little testing to do because the single core Meson3 model ROMs are just a little different from the dual core Meson6 ROMs, but I should be able to get these posted by this weekend.
        ShaunMT
        Freaktab Rom Developer
          It'll be awesome to be able to use my tablet again on wi-fi, I rooted my tablet as i root all my devices, but i was one of those many ppl in the forum that didn't read that my tablet when doing the change messed up my wi-fi, wrong drivers, but i did this almost probably 2 months ago, will be great when i can use my tablet again, we need to give shout out to shaun for the hard work and one of the only ppl out there who is working on roms and fixes for this tablet when nobody else is or will.
          Pantera
            Originally posted by Eugene_V View Post
            Hi Shaun, is been a long time. I tried many times to do a nandroid backup and send it to You but the application always fails to install on tablet.
            Hi, the app refuses to install on a 7" tablet Yfang Nextbook mod. Next7P12-GP (I-Fun) Android 4.1.1 (rooted, with busybox and terminal installed) manufactured in july 2013, sn # YF081301858.
            What could I do pls?
            Rgds
            Eugene
              Rgds
              Eugene
              No worries... I'm currently testing new ROMs for this model and expect to release them very soon.
              ShaunMT
                Next7P12-GP (4GB) "Apps don't move to SD"
                ShaunMT
                The board version is YIFANG PHM727MC_GPNTC100
                ota verson id: V.2.0.2IML74K.user.root.20130719
                cpu - armeabi-v7a
                Jellybean 4.1.1
                The sole problem I have is still that apps do not move to the SD. Checked on previous model (without the HDMI) - all is ok.
                Still hesitate to mess with the system wthout any (and reliable) full recovery.
                rgds
                Eugene
                  cpu - armeabi-v7a
                  Jellybean 4.1.1
                  rgds
                  Eugene
                  Are you trying to move apps to the external SD card? I don't think I can do anything about that...
                  Have you tried TWRP yet?
                  ShaunMT
                    ShaunMT
                    no, to the build-in. But they all stuck in the internal memory as well s ownloads and updates, I can't istall mor than a dozen on apps. Even some updates can't be done.
                    Not yet. Which one?
                    the SMT_TWRP_Next7P12-4G-POM727MC_1G.zip ?
                    Eugene
                    Last edited by Eugene_V; 21 May 2014, 16:50. Reason: SMT_TWRP_Next7P12-4G-POM727MC_1G.zip
                      Some apps can't be moved at all and others only partially move... are you using the system settings app section to move them? Are you getting an error?
                      Not yet. Which one?
                      http://www.freaktab.com/showthread.php?12618-TWRP-Recovery-with-UBIFS-Support-For-Amlogic-Nextbook-Tablets-(Download-Thread)&p=174961#post174961
                      ​ShaunMT
                        ​ShaunMT
                        Yes, getting error. Everytime says "couldn't move app". Memory is quick filled. Before You said that this is an option to be enabled in the original build and a custom ROM might be needed.
                        I already checked this but the board is not the same. Anyway I will try then if this works for me.
                          Have you checked the storage settings to verify that the internal SD card is mounted and not full?
                          ShaunMT
                            ShaunMT
                            We've been already through this. Yes it is mounted and nearly empty. No problem with read/write. just all apps and programm downloads are on the system memory and filling it completely.
                            Eugene
                              ShaunMT
                              Yesterday i've tried with the android sdk and the command "adb shell pm set-install-location 0/1/2", where 0=auto, 1=internal storage, 2=external,but no success. Actually "pm get-install-location" shows 2, but I get the same error message. And in the settings/apps the USB storage app is 0.00B and SD card also at 0.00B.
                              Appearently this command has many other options what should be moved to the SD.
                              Eugene
                                Eugene
                                In settings / storage you should have the following:
                                Flash (This is your total NAND Flash Memory and may indicate how much is used by firmware)
                                App Storage or Internal Storage (this is your /data partition, on an 8GB tablet it should be nearly 1 GB total, on a 4GB tablet it should be nearly 500 MB)
                                NAND Storage or another Internal SD Card (this is your internal SD Card, on an 8 GB tablet it should be about 5.5 GB total, on a 4GB tablet it should be about 2.5 GB total)
                                SD Card or External SD Card(This is your external SD card - you can't install Apps here)
                                USB Storage (This is for external USB drives - You can't install apps here either)
