I'm going to try to block out some dev time this weekend. Getting the unbrick kits and new ROMs tested and released for the Next8HD8G's are first on my list. Getting CWM recovery and new ROMs released for the Next7P12-8Gs is next.
FYI. CWM recovery will allow you to do a full nandroid backup that will dump everything but your bootloader and restore those backups when desired. Also, all new ROMs will include a script that will dump your current bootloader, along with a copy of your build.prop and dmesg output to your external SD card before the install begins. Assuming you also make a nandroid backup before installing, this will ensure that if an incompatible ROM is flashed in the future, you'll be able to upload your stock backups so we can quickly make an unbrick kit and stock ROM compatible with whatever model version you have.
ShaunMT
