Amlogic Next7P12-8G Modified Recovery - Stock Rom & Flashable Root
    Originally posted by EXV View Post
    Just wanted to confirm installing SU and the modified recovery works flawlessly on my Next7P12-8G, serial YFG06132615587. Question, I noticed my stock ROM is 4.0.4. Is this the same version as the stock ROM you provided in the OP?
    Also, is there anything I can provide you for a custom ROM or kernel? This thing is pretty slow and I would love to speed it up a bit with a new kernel. I can only provide donations or beta testing though. Haven't had the time to learn cooking yet.
    Thanks for the feedback.
    The ROM I posted is 4.0.4 dumped from someone else's Next7P12-8G.
    I'm working on custom ROM currently. Net yet ready for public testing.
    Not yet sure if I will be able to do anything with the kernel. There isn't any device specific source code available. I'll take another look at in the future, but it looks like it's going to require porting a lot of code of other devices.
    ShaunMT
    Freaktab Rom Developer
      ShaunMT
      Looking forward to the custom ROM! I really hate how slow this device is (I got it for free from a friend) and I know a custom ROM would patch things up a bit!
        Well, I can't overclock it without a custom kernel, and that isn't going to happen anytime soon because the full source code isn't available. I might be able to patch something together by porting code from other devices, but it isn't a priority right now.
        When I do start working on the custom ROM for this device, I'll see if I can least get it upgraded to 4.1. That should run a little smoother.
        ShaunMT
          ShaunMT
          Again looking forward to it! If you accept donations, I'd like to buy you a beer or coffee. Least I can do for giving this tablet root access and much more usable.
            You can use the donate button in my signature.
            ShaunMT
              New here and already amazed!
              So after months of looking for a root method for my Nextbook 7, i came to find out today mine was Amlogic, and i flashed it and rooted it thanks to shaunmt, in a mere 2 minutes! Thank you so much man!
                ShaunMT
                Donated. Thanks again!
                  ShaunMT
                  Hi Shaun:
                  I just got a Nextbook NX8HI (NX008HI8G) and I can't root it for the life of me. Perhaps you can help. I will also dump the ROM for you (which I am learning to do while typing this) if I can, so you have something new to play with. I'm sure it's damn close to the NX007 but nothing seems to work. Just pm me or reply on this thread, as I created this profile just to chat with you
                    Originally posted by Stragen View Post
                    Hi Shaun:
                    Have you tried Cydia Impactor?
                    I'm not sure, but the NX008HI8G looks like a NX008HD8G, but with higher resolution and possibly no HDMI out?
                    ShaunMT
                    P.S.> I'm going to try to move these posts to a new thread about the NX008HI8G...
                      recovery
                      Ok just how do I get into recovery on this thing???? It is NX007HD8G. I have tried holding power and both volume buttons. Power and the right volume and power and the left volume....I cannot get it into any recovery what so ever!!! I just want to root this poor thing!
                        It is usually power and volume -.
                        ShaunMT
                          WIFI Not Working after ROM update!!!!
                          I am able to successfully update the ROM provided, put after after update everything works except WIFI, any help on this please.
                            You installed it on a Next7P12-8G, correct?
                            Problems with WiFi or SD cards, are usually due to a bad flash.
                            Try wiping cache. If that doesn't fix it, try it again.
                            If that doesn't work, try wiping data. If that doesn't work, try it again.
                            If that doesn't work, flash it again.
                            ShaunMT
                              ShaunMT
                              Hi Shaun..Thanks for your response.
                              Yes it is Next7P12-8G, I tried the above, even I tried to reflash again using a formatted SD card but the issued remains the same (WIFI is not getting enabled).
                              ANy help is much appreciated
                                Myself and others have had similar issues with WiFi after flashing on other models. For myself, it took several tries to get it working again. I suspect I may have some bad NAND blocks on my tablet.
                                Try reformatting your SD card, redownloading the ROM, wipe cache and data (twice), then reflash again.
                                ShaunMT
