Can your CWM Zip tool be utilized for other PiPo tablets (M8Pro 3G or UpU1)?
Also to clarify, at least for me, I ask if my understanding of your "readme" is correct as follows:
1] To use this CWM ROM Update installer you must have CWM already installed and the current ROM parameter configuration on the tablet must be compatable with that of the ROM to be utilized.
2] In Windows, use 7-zip or similar .zip software to copy the following files from the ROM folder into the root of the zip file. (what Compression Method?)
system.img
boot.img
kernel.img
3] Rename .zip file to 'update.zip'.
4] Once you have added the files to the .zip, copy it to the tablet (what location?).
5] Reboot the tablet to CWM recovery and install the zip file.
NOTE: I recommend doing a factory reset from CWM too. Currently I advise using funs CWM.
