- based on 4.2.2 JB
- support old and new revision (B351_V2.0)
- preinstall es filemanager, reboot, hwkeyboardhelperdemo
- tvout fix
- 1080p/720p boot and kernel images
- cwm-recovery
- rooted
- init.d support
- 1080p-24hz, 1080p-30hz, 1366x768p60hz support
- nfs, cifs, ntfs, cdrom filesystem support
- add launcher switcher
- add auto hide systemui
- add eth notification title
- add screenshot
- remove google searchbar
- remove cpu/ddr lock on rk3188t
- stock ir remote fix
Link download:
firmware without kernel for B351_V2.0 :
http://www.freak-tab.de/wasser/firmw...sser-1.2.5.zip
firmware without kernel for B351_V1.x :
http://www.freak-tab.de/wasser/system-t-r42-old_rev.zip
1080p/720p kernels for old revision:
1080p/720p kernels for new revision:
version 1.2.4
- support Ugoos UT1, K-R42, T-R42, all reversions
- preinstall xbmc, es filemanager, reboot, hwkeyboardhelperdemo
- update kernel, improve suspend/resume, stability
- 1080p/720p boot and kernels
- cwm-recovery
- rooted
- init.d support
- improved video streaming
- 1080p-24hz, 1080p-30hzi, 1366x768p60hz support
- nfs, cifs, ntfs filesystem support
- allow user to set static ethernet mac adress
Link download:
CWM recovery
cwm-recovery-081213.img
oc kernels
kernel-t_r42 cpu1704_ddr720_1080p_gpu600h
kernel-t_r42_cpu1704_ddr800_1080p_gpu600h
kernel-t_r42_cpu1800h_ddr720_1080p_gpu600h
kernel-t_r42_cpu1800h_ddr800_1080p_gpu600h
kernel-t_r42_cpu1920h_ddr720_1080p_gpu600h
kernel-t_r42_cpu1920h_ddr800_1080p_gpu600h
Version 1.2.3
- all feature from 1.2.2
- fixed wifi regression
- fixed bluetooth regression
- preinstall xbmc
- passthrough support in xbmc
- fixed lan rx network traffic
- fixed bug in formating the NAND Flash, sdcard is mount correctly
- fixed bug in tv-out
- updated kernel, improved suspend/resume, stability
Link download:
t-r42-wasser-1.2.3.zip
Be aware: it is your own risk!
please post your feedbacks, it's very important! and don't forget to report the firmware version you flashed
