And mine. Looks identical to dim's, but might help anyway.
T-R42 - wasser firmware - JB Android 4.2.2
Originally posted by limecat View PostAnd mine. Looks identical to dim's, but might help anyway.
YOU HAVE TO FLASH THE STOCK KERNEL TO GET THE CORRECT LIST
what you need to do to get the gpio list correctly:
1 flash the stock kernel on my firmware. It's important that you use stock kernel!
2. fellow the link i posted to get the list
Could you please try again?
Originally posted by wasser View Postfirst thanks fir the gpio list, sadly it's not correct
is my attachment correct?
I will try to get a dmesg dump before and after a I re-enable the wifi/bt.
(Note: The kernel I used is from Oct 26 release for JESURUN not the geekbuying release).
Edit1:
I believe the attached dmesg is with the wifi/bt disabled.
Unfortunately as soon as I try to enable the wifi, I get the reboot loop again,
so I can't get any dmesg dump.
Edit2:
I have just realized that the firmware for JESURUN and t-r42 could be the same, maybe not exactly the same. Both firmware filename has this format:
RK3188T_BOX_SZTENA_B351_AP6210_(BUILD_DATE).img
The latest from geekbuying:
RK3188(T)_BOX_SZTENA_B351_AP6210_20130927.img
and JESURUN:
RK3188T_BOX_SZTENA_B351_AP6210_20131025.img
Edit 3:
I've compared limecat's dmesg dump with the one I have.
It appears that on my stock kernel gpio3 pin 279 is used to power on the ap6210 while on wasser's it is used to wake up the host. On the stock kernel the wake up host is in pin 282 while wasser's is null.
(This is, of-course, assuming that the number after gpio3 is a pin number)Attached Files
Originally posted by dim View Postwasser,
Can you give me the stock kernel?
I have stock ROM, but only in IMG format. I dont know how to get the kernel from IMG..
That's the one to use to extract separate images from one big .img file.
Something else
Hello wasser,
I was to late...the first thing I saw here, was that you're looking for somebody with a stock FW
to get gpio from. I got my T-R42 yesterday, but I reflashed it early in the morning. DAMN!
The 1.2.3 firmware is very nice !
Busybox, Ethernet w. static IP, Watchever ... and much more,
everything's fine except the issues with bt/wifi and the old struggle with the Motorola Lapdock.
The lapdock thing is maybe a little bit off topic here, therefore I moved my solution here.
I compared the dmesg output of 3 hdmi devices and was able to get the same dmesg output on lapdock with the first step in the linked post. I'm quite sure that the patch would fix problems with monitors with to less (or wrong) CEA resolution modes. (The two working hdmi devices skipped the CEA stuff in your kernels, anyway)
I don't know what you've changed in your kernels, but I would be very happy If we could try
the lapdock thing again.
And again, I can't find a Donation button. I would spend some beer for your whole
work. Thank you very much !
Gerry
Edit1:
Edit2:
and JESURUN:
Edit 3:
Hi imet,
your dmesg log with the stock kernel is correct. could you please use the script gpio_dump.sh to dump the gpio with wifi-off/bt-off and wifi-on/bt/on again? The gpio_dump.sh gibt more infos!
thanks
thanks
I will post back if I could enable the wifi and not have a loop reboot.
I will try enabling bt first. and do a dump again.
Edit1:
Added dump with bluetooth ON.
Edit2:
As soon as I enabled the wifi it reboots and loop again.
I don't know of anyway to get a dump if I can't connect with it using adb.Last edited by imet; 24 November 2013, 21:50.
Gerry
It would be great if you could test and post the results, don't forget to post the gpio list with the new kernel
Originally posted by imet View PostThe attached, is with the wifi/bt off, ethernet on.
Edit1:
Edit2:
could you please download and test? please post the gpio list with rhis new kernel
Originally posted by wasser View Postimet, thanks for the gpio list. I uploaded new kernel which has the gpio fix for bluetooth/wifi
The attached is withe wifi/bt off.
Originally posted by imet View PostThanks for the update, unfortunately the same reboot loop happens after I enabled the wifi.
thanks your great testing!
There are currently 2017 users online. 1 members and 2016 guests.
