T-R42 - wasser firmware - JB Android 4.2.2
Originally posted by veclinux View Post
This is the best OFW for 2.0: Ethernet, Wifi, Full HD - all works!!!
hi guys,
im new here because of a problem with my new t-r42 box
last week i flashed wassers 1.2.2
so far without problems, but ethernet, wlan and bluetooth doesnt work
i wanted to flash the 1.2.3 version to see if the problem gets solved
but after flashing 1.2.2, the box want other usb drivers than before
the drivers included in the 1.2.3 package doesnt work
before the 1.2.2 flash it wanted drivers for rk3066 and now after flash it wants drivers for rk3188
i tried to force the old drivers, but no success
also tried different driver package from different sources... nothing...
have i done something wrong?
so actually i cant flash with the pc
hope u can help me
hope u can help me
Originally posted by sebastianabate View PostWasser, can you make a parameter file that increase the data partition to use almost all the nand flash, by reducing the sdcard partition to the minimum? I managed to extract all the files from your ROM's img, but I have no idea how to modify the parameter file to do this.
I'm thinking on purchase a USB HDD and mount it as internal sdcard, this way I can install several huge games (those with more than 1 GB of data, like Asphalt 8 and Fifa 14) simultaniously, manage my large video library (more than 5000 videos) with XBMC or Mizuu, and I'm going to have a lot of space to install any number of APKs in the data partition.
Originally posted by Requan View PostYes, it is good idea.
Wasser: Could You tell us what do You need?, we will provide it.
PS
I would like to add, after flashed 1.2.3 and push power button, there is no power on board (i pluged pendrive and diode in pendrve wasn't blinking)
Hi wasser i have been trying to flash cwr but i can't get it to work i was usinnnnng flash tool 1.3.7 as stock tool can't support parts have you got a clockwork recovery that works a cwrrr update pleaseMy Device: T-R42
ROM: Wasser ?????
Peripherals: 5Port USB-2 Hub : Logitech K700 Keyboard : Buffalo 1TB HDD : 32 GB MicroSD : Wireless Xbox360 Controller : 5amp switch mode power supply
Originally posted by wasser View Postthere'are some paramter files in the 1.2.2 firmware. You can extract these files to use
I already read the whole thread, but I didn't find this information; can you tell me how much is assigned to the data partition with this two files?
Thank you again.
Originally posted by sebastianabate View PostThanks, I have extracted the parameter files from your 1.2.2 ROM; I have three files: parameter, parameter8 and parameter10, I assume that the first one is for the standard 2GB data partition, but the other two filenames seems to indicate that they are for 8GB and 10GB data partition respectively and we only have 6GB in our T-R42 for the data and sdcard partitions.
Thank you again.) and I managed to make a parameter file with a 6 GB partition for /data and a 350 MB partition for /sdcard; here is the file
parameter.zip
Originally posted by wasser View PostPlease provide dmesg.log from stock kernel
Thanks for answer, i read to get this log i have to type in terminal emulator:
su
dmesg>/sdcard/dmesg.txt
but after typing su i got error: "uid10062 not allowed to su"
Originally posted by wasser View Posti need name of your wifi/ethernet/bluetooth chip.
Could You do one more favour?
I can't open my box because warranty seal. You wrote that You have just opened Your box, Could You write down name of chips Wasser asked?
Wasser's firmware works many times faster that OFW, so i think many people would like to have it.Last edited by Requan; 05 December 2013, 17:59.
Originally posted by gerry1980 View PostHello wasser,
unfortunately, it doesn't work.
I got 2 dmesg dumps. One from the kernel-t_r42_cpu1800h_ddr800_1080p_gpu600h
and one from the working t-r42-kernel-241113-1.img.
In the working one, Sink info looks good, and appears just once:
<4>[ 1.306250] Support video mode:
<4>[ 1.309480] 1366x768p@60Hz.
<4>[ 1.312359] 1280x720p@60Hz.
<4>[ 1.315259] 1280x720p@50Hz.
<4>[ 1.318138] 720x576p@50Hz.
<4>[ 1.320929] 720x480p@60Hz.
<4>[ 1.323733] ******** Show Sink Info ********
In the non working, it appears twice:
1.
<4>[ 5.084351] Support video mode:
<4>[ 5.084360] 1920x1080p@60Hz.
<4>[ 5.084368] 1920x1080p@50Hz.
<4>[ 5.084376] 1920x1080p@30Hz.
<4>[ 5.084384] 1920x1080p@25Hz.
<4>[ 5.084391] 1920x1080p@24Hz.
<4>[ 5.084399] 1366x768p@60Hz.
<4>[ 5.084407] 1280x720p@60Hz.
<4>[ 5.084414] 1280x720p@50Hz.
<4>[ 5.084422] 720x576p@50Hz.
<4>[ 5.084429] 720x480p@60Hz.
<4>[ 5.084437] ******** Show Sink Info ********
2.
<4>[ 5.834095] ******** Show Sink Info ********
<4>[ 5.834109] Support video mode:
<4>[ 5.834119] 720x576p@50Hz.
<4>[ 5.834127] 720x480p@60Hz.
Maybe it helps you to fix that issue again.
Thank you !
Gerry
I just want to know if my info was helpfull for you, or what else I could do, to support you by that issue.
Greetings,
Gerry
There are currently 2561 users online. 0 members and 2561 guests.
