T-R42 - wasser firmware - JB Android 4.2.2
    Originally posted by krisvansnick View Post
    not sure if he needs more info?
    He asked for name of chips from 2.0 board. I can't provide it cause warrianty seal. If anybody can it will be very helpful.
      I'll open mine again and take high res pictures of the chips. Just curious what warranty sticker is there? I didn't notice anything.
        Thank You very much for You effort.. Now Wasser has all what they need.
        Mine has sticker on case, so i can't open box. Sticker is depend on supplier, so if You didn't notice, it means You don't have
          CWM Recovery for T-R42
          Originally posted by wapvirus View Post
          Hi wasser i have been trying to flash cwr but i can't get it to work i was usinnnnng flash tool 1.3.7 as stock tool can't support parts have you got a clockwork recovery that works a cwrrr update please
          i uploaded new cwm recovery, it should work on t-r42. Could you please test and reports the results!
          thanks
            ... it doesnt work for me..
            flashed it with finless tool.. box will no more start ..
              Waaser-Testing
              Hello Wasser,
              First: I re-flashed Your 1.2.3 T-R42 Image...(Clean)
              Restart Player.
              Second I used the 1.37 Flash Tool You gave us with Your 1.2.2 Images ...
              Flashed Recovery image Worked Fine ...
              I used The Reboot App to Restart in Recovery Mode ...
              The Player Restarted Fine and I can See The Menu ...
              But NONE of My Remotes Work ... I Have 2 Different USB Air Keyboard/Mouses and One Optical None of them Work ...
              I do See a Nice Screen showing Android Recovery <3e>
              Then I walk away and the System Rebooted by itself ... (80 seconds or So )
              I came Back and Shut it off and Restart and used the Button on Bottom of player
              to Start Recovery and Now The USB Air Mouse/Keyboard Works but NOT the Optical ...
              I am waiting to see if it reboots again ...
              Results from First Test ...
              Michael T.
              3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
              CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
              Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
              Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
                did you flash it with correct parameter? it's very important!
                  nope. only checkboxed recovery.img
                  soo.. i have fresh installed 1.2.3 and then with the tool from 1.2.2 i flashed the recovery.
                  no cwm - only black screen
                    Parameter File
                    Hello Wasser,
                    Could You please post a link to the parameter File You want us to use When Flash the Recovery image ...
                    Please Check Your PM ...
                    Michael T.
                      Originally posted by larzer View Post
                      i have boardversion 2.0 to
                      good to see where the problem is but i still have another problem which makes me cry
                      i used the same drivers as for the flash of the 1.2.2 version
                      but now, after the flash the box doesnt accept the drivers anymore
                      tried on 3 computers, one win8 and two win7
                      and as long as i know this box has a rk3188 chip
                      so why it now shows me rk3066 in my hardwaremanager and want drivers for it?
                      i dont know what i should do anymore, used drivers from different sources and the driver autoinstaller of rockchip... nothing.....
                      please help me
                      I have the original old revision T-R42. It works flawlessly with Wasser 1.2.3. However, I recently ordered two more T-R42's. They are version / revision 2.0 and now both will not boot with Wasser firmware 1.2.3. Hopefully, Wasser can create a new firmware for the new 2.0 revisions.
                        Originally posted by michael2t View Post
                        Hello Wasser,
                        Michael T.
                        info for recovery flash:
                        1 download the new t-r42 cwm-recovery image
                        2 unzip the 1.2.2 firmware
                        3 launch RKAndroidTool.exe and only select misc image (it's included in 1.2.2 zip file) and recovery image
                        4 change address for recovery to: 0x00014000
                        5 click flash
                          Wasser:
                          Finally i rooted my box (2.0) and created dmesg log - please find in attachment file.
                          wapvirus:
                          Please read my post one more time, i had problem with detect device by tools only, no with way how to do it, but never mind because i have solved it
                          could you please attach gpio debug log from stock kernel with wifi and bluetooth enable? it's very important to make wifi and bluetooth working.
                          Please take a look at the url how to get the gpio debug log.
                          thanks
                            Wasser -Testing
                            Hello Wasser,
                            Testing:
                            1) Reflashed 1.2.3 Firmware and Restarted Player
                            2) Follow Below Instructions
                            A) Player Will NOT restart LED on Button Turns Off
                            B) Plugged Player Blue LED turns on for 30 seconds and Then turns off
                            C) Player Will NOT Boot ...
                            NOTE: Player Booted Fine When Flashing Just Recovery image at Default Location:
                            With Botton on buttom of player and Does NOT boot Correctly with Reboot App..
                            Test Results Complete.
                            Michael T.
                            5 click flash
                              thanks
                              I enabled wifi and BT only and made log.
                              Here You are:
                                Here You are:
                                could you please post the lsmod log? just do in termimal:
                                lsmod >/sdcard/lsmod.log
                                thanks
