T-R42 - wasser firmware - JB Android 4.2.2
    Originally posted by veclinux View Post
    I uploaded the chinese rom to my ftp site you can find it here:
    hope that helps!!
    anxiously awaiting Wassers new rom................
    cheers,
    Vec
    veclinux:
    Do You have also access for newer version of firmware v1? I need it for my friend because his OTG USB didn't detect pendrive correctly.
      Originally posted by baxxtor View Post
      On the back of the box, if you have a empty sticker plate its version 1.0. If that sticker plate actually has a sticker on it with a serial number that says "smart android box", it is version 2.0. In your case, it sounds like you have version 1.0
      Not in my case. A have a V2 without a sticker at the back.
      Rk3188 / 1346 / CH001 / B351_V2.0 / 2013/09/22
        That is right, it is not that simple. According to geekbuying, if you have a sticker (like picture below), then the S/N first characters will tell you (BXnnnnnnnnnnn means a v1 board). If you do not have a sticker, you are out of luck and have to open the unit and read the board version from the board itself (it should be printed in one of the PCBs extremity).
          hope that helps!!
          cheers,
          Vec
          Hey Vec - I cannot find the file in the URL you provided. I can go up to directory http://vectorlinux.osuosl.org/vec7/ but no subdirectory androidtv in there
            Give it a try now sometimes takes a bit to populate our outside mirror sites.
            Cheers,
            Vec
              Cheers,
              Vec
              Tried again and was able to grab the file. Thanks!
                has anyone tested CH001/1338 B351_V1.1 with the firmware
                Hello pleas help
                  Originally posted by mg0179 View Post
                  Hello pleas help
                  Yes, it works but only with 1400Mhz cpu power
                    why this ? not 1600Mhz CH001/1338 B351_V1.1 with the firmware
                    this buy by **** =Android 4.2 A9 HDMI Mini PC TV Box Smart TV Quad Core Bluetooth WLAN 8GB 1.6Ghz
                      donĀ“t know
                      I have the same box and told the freq-problem to wasser...
                      hope he makes the kernel for our device soon...
                        thanks for the information,
                          Hello pleas help
                          I have two 351_1.1 and have problem with wasser 1.2.3 - sometime crash video player(mx,bs,any) when play online video (hw decoding)... and very bad works torrent.
                            I figured out how to get LAN working on the B351 V2.0 boxes, the trade off is losing BT/WIFI.
                            Flash 1.2.2 let the box reboot after it's done.
                            Go back to recovery
                            Flash the new cwm recovery + the kernel that wasser linked in the thread.
                            It should boot up fine and will give you working LAN, so those that require LAN connections should have a temp solution until another custom rom comes out or wasser updates.
                            Please test this out and let me know what your results are. I DO NOT RECOMMEND ANYONE WITH A 1.1 board to try this.
                              Go back to recovery
                              awesome, I tested it this morning and worked !!
                              thanks
                              still having problems with SPDIF audio & 720/1080p streaming from nas
                                Go back to recovery
                                did it but i've got no HDMI output :/
