T-R42 - wasser firmware - JB Android 4.2.2
    Originally posted by Herzie View Post
    Thx looking forward to trying it. Any changelog, or is it just support for all boards?
    Change log is in the download...
    29.12.13
    - release 1.2.4
    - support Ugoos UT1, K-R42, T-R42, all reversions
    - preinstall xbmc, es filemanager, reboot, hwkeyboardhelperdemo
    - update kernel, improve suspend/resume, stability
    - 1080p/720p boot and kernels
    - cwm-recovery
    - rooted
    - init.d support
    - improved video streaming
    - 1080p-24hz, 1080p-30hzi, 1366x768p60hz support
    - nfs, cifs, ntfs filesystem support
    - allow user to set static ethernet mac adress
    Thanks Wasser!
    Bill
      v1.2.4 seems to work well with my v1.0 T-R42. I used the 720p/old files. BT and WIFI work.
      Is there no auto hide or the system bar, or it hidden elsewhere this version?
      Bill
        What about this one? Which version is it?
          v1.2.4 seems to work well with my v2.0 T-R42. I used the 720p new files.
          At the moment all is working well!!!
          Thank you very much and congratulations for your great work.
            I'm using v1.2.4 on a v1.1 board, with 720p kernel/boot, and everything is working OK, (WiFi, Bluetooth and Ethernet; I did not test the remote because I run out of batteries :-P ), and as usual is very fast and stable. Thanks for another excellent Rom @wasser.
            I have a couple of questions:
            1) Why on all of your roms the CPU is limited to 1.4 GHz? The stock kernel/rom works OK with 1.6 GHz
            2) Is the LCD Density "hardcoded" in some way? I installed Build.prop Editor, added ro.sf.lcd_density with a value of 160, then 140 and then 120, but in every case, after reboot I don't see any change in density
            3) Can the Reboot App do any type of umount or sync before shutdown/reboot? I'm asking this because I have an external USB HDD with an ext4 partition, and I want to be sure that it is correctly unmounted on shutdown/reboot
            4) Why we can't set the I/O Sched on this devices with SetCPU? (this is not limited to your Rom, I can't set it on stock Rom either) I can set it on my tablet (Pipo M8 Pro) so I know that it is not a limitation of the SOC.
              Problems with Video playback
              Originally posted by wasser View Post
              Hi all.
              firmware-wasser-1.2.4 is uploaded. It should support all known T-R42 boards, Please select the correct kernel included in zip file by flashing.
              enjoy!
              http://www.freak-tab.de/wasser/firmw...sser-1.2.4.zip
              Great work so far, thanks!
              I just have a problem with video playback, which I had with 1.2.3 as well but not with 1.2.2. I'm using the 1080p old kernel and everytime I'm playing a movie (whatever format) using any Video player (using NFS thru ES File Explorer) it stops after 15 to 20 minutes and throws me back to ES. It's very annoying...
              Anyone an idea what might be the cause?
              Cheers,
              niewi
                My wifi Problems are blown away! Thanks for this
                one question. When i use the 720p Kernel. Is Video Playback in 1080p possible? I Flashed 1080p boot and Kernel , but Gaming Performance Would be better with 720p
                  Could You confirm if am i right?:
                  I upload Kernell 720p when i set up in box 720p resolution and 1080p when i set up in box 1080p?
                    yes, it's possible
                      you should setup the resolution to 720p if you flash the 720p kernel
                        Cheers,
                        niewi
                        i cannot reproduce this issue, i did a video stress test (playing fullhd movies 12 hours) without any issue.
                          Originally posted by openbeta View Post
                          This rom have 1366x768@60hz support like the k-r42 one ?
                          if not, there is anyway port it from k-r42 rom?
                          i have ordered a T-R42 but i have a 51" plasma which the resolution is 1366x768.
                          yes, 1366x768 is supported in this rom
                            Originally posted by MattPaul View Post
                            No custom ROM works by me, please help!
                            [ATTACH=CONFIG]4603[/ATTACH][ATTACH=CONFIG]4604[/ATTACH]
                            it looks like k-r42 new revison, please flash the 1.2.4 firmware, the correct kernel is kernel-1080p-k-r42-new.img
                            please let me know if it works!
                            thanks
                              Got some more time to play with this version last night. 1.2.4 is working much better than any of the previous versions. Wifi seems to pick up signals that previously it hadn't. My SSID shows as a strong connection. No streaming issues. Bluetooth doesn't have any issues.
                              The version of XBMC is quite nice too. Great mouse support, and it plays videos that I was previously unable to play on 1.2.3.
                              Skype v3.2 now works with my Logitech c270 video camera as well.
                              Any help on the lack of autohide system bar? The style that was included in previous versions worked well. If this isn't possible, any recomendations?
                              Thanks!
                              Bill
                                thanks
                                Has the new K-42 kernel revision Bluetooth on it? Because I have the bluetooth version which should be the T-R42 version. There are 2 common revisions of T-R42 - rev.1 and rev.2, but I don´t have any of these two and I hardly doubt that it is the new revision of K-R42. I will try it, but don´t have much time so if I will brick it, I will lose everything on it again.
