From the messages here it seems there must be a new version out of the T-R42 with different hardware. When you have one of those new boxes then the current firmware here will not work for you (no BT, no WiFi, no Eth).
Maybe wasser can build a version that works for the new box, but he will need a dmesg output from stock firmware. To get that, flash the correct stock firmware that works with your box, then root your box, and then in a terminal run su followed by a dmesg > /mnt/sdcard/dmesg.txt Afterwards attach the dmesg.txt to a message here. Hopefully wasser can then help you.
