T-R42 - wasser firmware - JB Android 4.2.2
    testing
    Other than wifi it's a very good one Wasser. Been feeding it a 1080p with 5.1 audio for the last hour and it appears rock solid. Sleep/resume also works great.
      firmware 1.2.3 is ready for download. wifi should be fixed
      Enjoy!
        Thanks wasser for your hard work!
        I will test the rom and let you know how it performs! Cheers
          Newbie
          Enjoy!
          First if all thanks for your incredible work! The commitment and effort you put in this is remarkable. I am a newby to android and just ordered a T-R42, the reviews and the input on this forum put me to it. I haven't received the device yet but I am trying to prepare me by following this thread so I can make a quick start when device is in. So far I am convinced I now know how to flash your firmware, connect device to windows, run RKBatchTool,Select Firmware and Restore! But my question is do I need to root the device first before I change firmware, or is it already rooted, or will it be rooted on the proces of flashing your firmware? Sorry for my Noob question, just dont want to do something wrong with the device. Thx.
            you don't need to root device before, it will be rooted on the process of flashing my firmware
              NEED HELP, important
              Hi all,
              I want to improve wifi and bluetooth for t-r42. for this i need the gpios list of wifi and bt from t-r42.
              Could someone please do this and post the gpio list? It's very important for me to make wifi/bt working correctly.
              Please take look at this, it shows you how to do:
                1080
                I am flashing this firmware and... where is REAL FullHD, no difference between 1080p and 720p?
                  CIFS & NFS support?
                  Hi All,
                  is there CIFS & NFS support in this firmware?
                  Thnx
                    Hi wasser,
                    Thank you for your hardwork!
                    1.2.3 firmware is perfect!
                    Great video quality, wifi and bt works well.
                    SDcard mount have no problem. @ CS918
                    Sent from my SHV-E250S using Tapatalk
                      Enjoy!
                      wifi not connecting (only saved pass)
                        Try to change wifi mode on the router. I had the same problem with b/g/n mode. After changing to b/g mode and auto channel its connects well.
                          also, bluetooth mouse stopped working after the second boot (this is the bluetooth regression?)
                            Originally posted by lkzcgfvf View Post
                            Hi All,
                            Thnx
                            both filesystem are supported in this firmware, please read my first post!
                              it could be that bt/wifi doesn't work 100% correctly. As i mentioned before i cannot fix bluetooth and wifi correctly without having gpio list.
                              i'm sorry, i cannot help if there's regression in wifi/bt
                                GPIO
                                Hi all,
                                Hi. The gpios list from T-R42.
                                Wifi and Bluetooth turned off.
                                gpio.txt
