T-R42 - wasser firmware - JB Android 4.2.2
Originally posted by Requan View PostI changed extension log on txt only, because forum's upload didn't accept file:
[ATTACH]4336[/ATTACH]
please report the result!
thanks
Flashed Recovery for 1.2.3. followed your instructions changing address to 0x00014000 now box wont boot turns off after a few seconds
Flashed stock to recover device ,Ant chance of you adding the new recovery image to 1.2.3. for us please wasser thanks again for your hard workMy Device: T-R42
ROM: Wasser ?????
Peripherals: 5Port USB-2 Hub : Logitech K700 Keyboard : Buffalo 1TB HDD : 32 GB MicroSD : Wireless Xbox360 Controller : 5amp switch mode power supply
Originally posted by wasser View Posti upload new 1080p kernel for t-r42 with new revision. Could you try to flash the 1.2.2 firmware with this new kernel ?
thanks
The box boots now and wifi works. However, ethernet gets a links light, but will not obtain an ip and I cannot set a static IP...so ethernet not working. Also, bluetooth is not working.
At least wifi works and the box boots. That is a good start!
Originally posted by baxxtor View PostWasser, as requested, on a new revision 2.0 t-r42, I installed your 1.2.2 firmware with your new version t-r42 kernel.
Cheers
Vec
Originally posted by veclinux View PostWasser just tried on my box congrats it boots and wifi works. I too have no bluetooth and lan does not get an ip although settings say its on. I agree GREAT FIRST START!!!!
Cheers
Vec
Please take a look at the url how to get the gpio debug log.
thanks
Originally posted by michael2t View PostHello Wasser,
Testing:
1) Reflashed 1.2.3 Firmware and Restarted Player
2) Follow Below Instructions
A) Player Will NOT restart LED on Button Turns Off
B) Plugged Player Blue LED turns on for 30 seconds and Then turns off
C) Player Will NOT Boot ...
NOTE: Player Booted Fine When Flashing Just Recovery image at Default Location:
With Botton on buttom of player and Does NOT boot Correctly with Reboot App..
Test Results Complete.
Michael T.
Anyway big thanks to you, michael, for tetsing!
strange
outdatedLast edited by michael2t; 10 December 2013, 18:54.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
Cheers
Vec
Thanks for Your effort. I also have wifi but no bluetooth and LAN.
Originally posted by wasser View Postcould you please attach gpio debug log from 1.2.2 firmware with wifi, ethernet and bluetooth enable? it's very important to make wifi and bluetooth working.
thanks
However, I have attached the GPIO dump while trying to enable each one. I hope this helps.Attached Files
Originally posted by vicolodo View PostHello,
i installed latest version of skype on my T-R42 with stock firmware and webcam logitech c270:
when i do a video call with my ipad or my notebook (running windows 7),
very often skype tries to open the window but then it stops and crashes on the T-R42,
showing in the down right corner of the screen 'skype not connected'
I dont know on what this depends,
i am wondering if the latest custom firmware by wasser solves this problem
Did someone test skype videocall with latest wasser custom firmware?
I read somewhere that skype 3.2 version is working better... is it true?
Thanks!
Originally posted by baxxtor View PostWasser, using your rom 1.2.2, I attempted to obtain the GPIO's. Wifi, ethernet or bluetooth will not enable.However, I have attached the GPIO dump while trying to enable each one. I hope this helps.
Originally posted by Requan View PostWasser:Thanks for Your effort. I also have wifi but no bluetooth and LAN.
There are currently 2242 users online. 0 members and 2242 guests.
