T-R42 - wasser firmware - JB Android 4.2.2
Originally posted by tomascastaldi View PostHas this rom (1.2.3) works on v2.0 base ? I hope you help me this question thanks
Originally posted by wapvirus View PostFirst for XBMC to work you need to enable hardware acceleration this is done in the buildprop of your device, That's why your findings are bad ,
I am working on a version to share here soon that can play back full 1080p videos and streams using XBMC built in player I Will post it here soon ,it is using rockchip hardware acceleration ( stagefright ) and plays all formats with no problems I am just recompiling a new build with plugins and repositories built in so I will post my work soon B-)
Sent from my HTCSensation using TapatalkLast edited by buhohitr; 01 January 2014, 20:46.
Thank you very much and congratulations
Good morning :
First of all Happy New Year to all and congratulations for your great job wasser .
I bought a few days in a T -R42 geekbuying ago, not as manufactured the device.
I have information on how to root devices, as I have rooteado Samsung Galaxy S1, Splus , S2 , S3 , S4 , and huawei G300 .
I know how this world works but for each device is different.
I downloaded the latest version 1.2.3 before doing anything I wanted to know a few things :
Do you have Spanish language ?
Is there a small tutorial on whether the device has been manufactured to do first, 1st root, 2nd connect to pc, etc ..... Mainly for not doing so bad ?
Did you install the version 1.2.3 or 1.2.4 to the best and hope I see you put it shortly and you will have improved enough niggles ?
Stayed pending a reply or at least someone can answer me the first 2 questions.
Thanks for this community that is a very interesting forum .
Thank you all. A greeting.
update
Good afternoon :
I have read in other forums as do the upgrade because it seems that no one here could help me at all.
From what I have been told it is not necessary to do before anything or install your CWM or give root.
1 Install the drivers on your computer
With a 2nd micro -usb standard usb cable like cell phones connect the device to pc .
With 3rd application that incuyes image selecionara image flash when it detects the device and to restore him .
There.
My only doubt is that the end of the thread put a fix to repair the remote control.
"Link download :
http://androidtv.b42.nl/wasser/t-r42-wasser-1.2.zipfix stock issue with my remote, please identify cwm recovery to flash the fix
http://androidtv.b42.nl/wasser/t-r42-ir-remote-fix.zip "
I wanted to know if this is necessary with 1.2.3 and upgrade if necessary as it is and as installed CWM as congratulate you put everything but put even a little tutorial for how to install updates or anything .
Originally posted by wasser View PostHi all.
firmware-wasser-1.2.4 is uploaded. It should support all known T-R42 boards, Please select the correct kernel included in zip file by flashing.
enjoy!
http://www.freak-tab.de/wasser/firmw...sser-1.2.4.zip
enjoy!
yes yes yes!!! Downloading now!
There are currently 2057 users online. 1 members and 2056 guests.
