T-R42 - wasser firmware - JB Android 4.2.2
Originally posted by wasser View Postyou can use them, but i recommend to not use them if you don't have any problem with playing of fullhd video
so i will try an overclocked kernel
but now another question, i am new to xbmc and used it first time with your rom.
the possibilities are amazing, but when i play a fullhd video from my nas over network, it stutters like hell.
when i play the same video with the mxplayer it runs nearly smooth, just some little stuttering.
any specific options to put on or why xbmc has this problem?
Android XBMC Hardware Acceleration
Originally posted by larzer View Postfullhd runs good, with some little stuttering
I will try both 720p kernal and 1080p, but it sounds like 720 is a better option for android xbmc.Last edited by Jethro; 10 January 2014, 21:24.
T-R42 v2.0
wasser, thanks a lot for your 1.2.4 fw!
So far, so good, it works on my B351_V2.0 box, except for bluetooth, but, tbh, bluetooth isn't really necessary: i am going to use a remote android app: droidmote and my smartphone to control the box,
I have one little question/feature request...
In the times when i had a Teclast T760 pad, i used to read a slatedroid forum where wendal was giving some clues, and once in a time, Aino made a new ROM and a parameter file to reconfigure partitions. I've found an error in his file, and made a proper one (he admitted it). I even wanted to write a GUI-routine to edit partition sizes in parameter file, but, unfortunately, i'm too old and dumb now, and too lazy/busy. The idea is the same, i told it on slatedroid forum: TFcards are cheap now, and most people can afford 16/32/64 card. Internal flash is usually configured in a dumb way, so that data partition is quite limited, and "internal flash" is remains, and, even if you have a 32GB TF card, most apps simply can not install to external card - you end up with full data and full internal flash quite soon! Idea was to give as much as possible to data partition, hide "internal flash remains" and make external flash a default install place. I have it like this on my KTK6589 smartphone, and it IS very convenient: i never think about spare place!
Someone can tell me why when inserting a memory card - internal card is not visible - but the games are transferred to it working properly. This firmware bug or not? T760 firmware ver 2.08(c)AINO
Can you make a partition file that could give 6GB to data, and a patch for vold.fstab to declare external flash as "internal" or default, or maybe a special system.img with it?
Thanks in advance!
[QUOTE=doperst;131106]wasser, thanks a lot for your 1.2.4 fw!
So far, so good, it works on my B351_V2.0 box, except for bluetooth, ...QUOTE]
I am having the same issue, Bluetooth will not enable on a Version 2.0 box. Unfortunately, without bluetooth, sixaxis controller will not work wirelessly
[QUOTE=baxxtor;131164]Originally posted by doperst View Postwasser, thanks a lot for your 1.2.4 fw!
Same here, hope for a fix because of my bluetooth keyboard
[QUOTE=svN89;131280]Originally posted by baxxtor View Post
my questtion to everyone: does bluethooth work for you? please post result and your exact hardware!
thanks
[QUOTE=wasser;131338]Originally posted by svN89 View Post
which hardware do you have exactly? Please post the dmesg.log so i can take a look why bluetooth doesn't work
thanks
Device Name :rk3188_box_szy_x6 (With Bluetooth AP6210)
v1_0 131024
Link;
Originally posted by galaxy View PostHow to set 1366x768 resolution? It is not listed in hdmi resolution list. Tried with both 1080p and 720p kernels. Have hd ready tv with 1366x768 native res. My box is t-r42 ver 1.1
adb shell cat /sys/class/display/HDMI/modes
T-R42 B351_V2 Board
Wifi works the first boot, after reboot don't work, if I reboot into recovery and reboot system, work again
Bluetooth doesn't work, the remote control lost some functions.
My hardware box is WLAN: RTL8723AS + LAN: RTL8201F
8723as.ko module isn't loaded into the kernel, the 8723au.ko module was loaded into the kernel, i don't know if this is correct.
If you need any information that could help you, feel free to ask me.
There are currently 2198 users online. 0 members and 2198 guests.
