T-R42 - wasser firmware - JB Android 4.2.2
Everything seems to work except Bluetooth...
Installed the ROM - overall everything seems to be working great except Bluetooth, when I click "Enable" it just goes back to "Disabled", Wifi works fine, Ethernet - Don't know (router is too far away).
My device is a T-R42, with B351 V2.0 Board
I installed Lewy's T-R42 2.0 ROM (http://www.freaktab.com/showthread.p...e-by-lewy20041) and everything is working properly, but Lewy is missing XBMC Passthorugh patches so was really hoping to get your ROM working...
Let me know if there's anything I can provide to help debug this.
Xtrm
So
Originally posted by xtrm View PostInstalled the ROM - overall everything seems to be working great except Bluetooth, when I click "Enable" it just goes back to "Disabled", Wifi works fine, Ethernet - Don't know (router is too far away).
[ATTACH=CONFIG]5223[/ATTACH]
Xtrm
Originally posted by timenewton View PostSo your wifi is working well? When it was working, it was very slow I did a speed test and it would only reach .5 down and .5 up
I switched to Lewy's "T-R42 2.0 Board" and replaced libmedia.so and used a patched XBMC version (from this post - http://forum.xbmc.org/showthread.php?tid=172223) to get AC3/DTS Passthrough working.
So far I'm quite pleased
I did notice few "weird" things:
1. If you do a Reboot the screen rotates "upside down", power-off & power-on fixes that
2. When the device is put into Standby mode, it powers back up on it's own after 10-15 minutes
Both are not critical issues, just an observation
Xtrm
Hmmm
Originally posted by xtrm View PostYea, Wifi worked fine - would get ~10Mbps with Speedtest.net, though I didn't test too much since I really need Bluetooth working, so didn't stick much with the ROM.
Xtrm
Just a thought, you sound pretty intuitive about software, would you be able to tweak it since he won't replay back? Or tell me what to do for better wireless transmission. Cause the reason I bought the T-R42 was to replace my old wd live tv box, but I really can not count on it if I can't stream wirelssly.
Originally posted by timenewton View PostJust a thought, you sound pretty intuitive about software, would you be able to tweak it since he won't replay back? Or tell me what to do for better wireless transmission. Cause the reason I bought the T-R42 was to replace my old wd live tv box, but I really can not count on it if I can't stream wirelssly.
Xtrm
for Wasser - Asking for help
This is the kernel from MK918 stock rom ...
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
Wasser please from all of us who have MK918 to turn it on in your sw, otherwise your rom working on our device with an old T-R42 kernel but not wifi and bt ..
wifi&bt Chip is AP6210 ... and processor is RK3188T
Thanks in advance friend ...
P.S. This device looks...
help
Hello,
my T-R42 with stock rom has shut down definitively...
Normally i keep it in operation (was about a week i didn't turn off it)
today i found it powered off,
and when i try to power on it pressing the button,
the button light stays on for a few seconds, then it (and the device) turns off
HELP! what can be happened?
How can i resuscitate my T-R42?
So 5V 2A or 3A. If you can find a universal adapter buy that
Originally posted by Zydeco View PostBuy a new power adapter. It has to be the same volt and atleast 2A(ampere).
i will try
Did you have the same problem?
i also suspect it is a power adapter problem, because the light stays on when the tv box is connected also to usb (otg)
There are currently 1476 users online. 2 members and 1474 guests.
