T-R42 - wasser firmware - JB Android 4.2.2
    Re: T-R42 - wasser firmware
    Originally posted by mpivar View Post
    I download wasser 1.2.5 stock rom, but kernel links are dead (please reload new or old links). I installed rom without kernel (in RKAndroid Tool I unchecked kernel square and install without kernel).
    Will this be OK? Or I have to install with kernel. Can someone please explain what does it mean ROM installation and what does it mean Kernel installation? Is it possible to install ROM without Kernel?
    If you install ROM only without a kernel then it keeps your existing kernel. Kernel only means you just flash the kernel and keep your existing ROM.
    Sent from my Galaxy Nexus using Tapatalk
      I flashed wasser ROM mainly because I have problems with Wifi speed download and internal memory unmounting.
      Are my problems ROM or Kernel issue?
        In most cases you should flash them in pair. WiFi issue usually driver issue, usually not compatible driver which it fails to load. You should flash both.
          Can I use OC Kernel Pack? Or it is best that I use Wasser kernel pack?
          Can you please upload Wasser kernel pack or maybe send it by mail?
          Thanks again for your help :-)
            I only have the old kernel for 1.2.5 which is for version 1.0 board, if you have 2.0 board then you need a new kernel version which I don't have. I would stay with Wasser kernel for now.
              Yes I have V2.0 board.
              Just one more question. I have downloaded OC kernel for V2.0. Can I use this kernels???
                Please give me the link to the kernel that you about to download, I need to verify it.
                    No, don't use them!
                    Can some one please provide a link for the new 1.2.5 kernel to help out a fellow flasher here???
                      Kernel
                      I have the new kernel version.
                      720p New http://www75.zippyshare.com/v/68113765/file.html
                      1080p New http://www24.zippyshare.com/v/37575089/file.html
                      enjoy
                        Originally posted by ollie26 View Post
                        You're theee man. Thanks!!
                          No, don't use them!
                          download url is fixed
                          wasser
                            wasser
                            Thanh you Wasser!!
                              Thank you Wasser
                                Hi Wasser, i just start to use cs918 RK3188-t quad core 1.6mhz (ver B351 BT)with bluetooth, i want to fix to use youtube, so i need to flash the rom to Wasser 1.25 ?
