T-R42 - wasser firmware - JB Android 4.2.2
V1.0 & V1.1 not working with 1.2.5 ?
Originally posted by mamo View PostI've installed 1.2.5 on my T-R42 B351_v1.1
After installation, the TV Box fails to boot. It shows just few frames of the start-up animation and hangs forever.
I had to downgrade to 1.2.4 firmware in order to make my TV Box to work again.
as I recall correctly, this is the first time in this thread I read
about somebody having problems with Wassers Firmware 1.2.5
and a T-R42 Device with V1.1 ?
Anybody else having problems with this set up ?
If so it might be another problem than guessed before.
I thought it was V1.0 specific.
May be Wasser can solve this ... hope so.
MakkuT-R42 V1.0 - Wasser Firmware 1.03 KitKat
Originally posted by el_easy View PostMy brother has EKB311b too, trust me! but I tried to flash many custom Rom none of them work..Always was Wifi or bluetooth problems, so gave up...
The only thing is work is Stock Rom is already rooted.. Enjoy!!
I guess this is your cover label right?
or
http://pan.baidu.com/s/1dDcfwYH
Originally posted by rceccleston View PostSince beta 1 of XBMC Gotham has been released, featuring hardware acceleration for Android and many other enhancements, it would be highly recommended to upgrade from Frodo.
The developers did announce that no future updates will be released for Frodo after 12.3 V7a.
Sent from my Nexus 4 using Tapatalk
With my setup 1.2.5 new 1080p boot and kernel works the best (b351_v2.0). With this software version the box is still sometimes finicky to awake. If it totally power off I have to play with it to power up. Sometimes I have to disconnect HDMI and then power on button for box to start up.
Flash 1.2.5 on T-R42 Old Version
Hello All,
I have both K-R42 and T-R42 old version both ..
The 1.2.5 K-R42 works fine ...
I figured out that the are files Missing in the System.img on 1.2.5 for T-r42 Old version
So Here is what I have done ... Until Wasser Gets it fixed ..
I flash all images except the system.img from 1.2.5 old version 1080p and
then I use the system.img from 1.2.4. and all works fine ...
This will get You alot of Wasser updates Just not all of them ...
Good Luck and Enjoy ..
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
Michael T.
that sounds as if the error is a bit more located now. Can y
ou list the files which seem to be missing or is it a good guess by you ?
I will try out what you have done at home tonight or tomorrow ...
Thanks for this
Errors With 1.2.5 T-R42 Old version
Thanks for this
Makku
Wasser Knows about the issue and Said he is going to look at it this weekend ..
Michael T.Last edited by michael2t; 14 March 2014, 12:25.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
There are currently 4949 users online. 0 members and 4949 guests.
