T-R42 - wasser firmware - JB Android 4.2.2
    I think it's probably best that I just leave this thread now before it starts to seem like I'm trolling. I don't take back anything I wrote before, but Wasser I am grateful for all the time you spent building this ROM for everyone except yourself to use! You've helped me out personally a couple of times with it too!
    Thanks.
      SANGER....
      Sorry SANGER, but i think "Be aware: it is your own risk!" is enough Warning! Yes its true, people who often flash roms didnt notice Warnings like that. But isn't it the same with smoking and cancer? Nobody has to flash a custom Firmware. If someone bricks his device....sorry for that, but this can happen with every board. Flashing is everytime a risk and there is a reason why youre losing your guarantee when flashing custom roms.
      Wasser has no possibility to test it on other Hardware. So how he could warn others if he cant test it??? For me its working great on my 2.0 Board. For a Friend its also working great on a 1.0 Board too...
      Wasser, thanks for your great workHope 1.2.5 is not your last FW and you keep up the good work! I really appreciate it!
      Regards,
      Mod
        Originally posted by DRMod View Post
        ... So how he could warn others if he cant test it??? For me its working great on my 2.0 Board. For a Friend its also working great on a 1.0 Board too...
        Hi DRMod,
        you are writing that you know someone who runs 1.2.5 on a Version 1.0
        May be you can convince this person to explain how he made it working?
        makku71
        T-R42 V1.0 - Wasser Firmware 1.03 KitKat
          Originally posted by makku71 View Post
          Hi DRMod,
          makku71
          Hi Makku71,
          i will ask my Friend today how he became it running on his 1.0 Board. I will update here later.
          Regards,
            I flashed many time, many roms(OFW, Wasser, Lewy and unknow sources too) my box, sometimes after flashing it didn't boot, but i never thought to blame anybody, but try to find solution (maybe because this is our Polish nature: don't cry because it don't work, but try to fix by Yourself).
            This devices has BOOTLOADER, trigger by button, so it has locale to different part of memory than firmware, so this is the reason to hard to demage this devices by uploading soft.
            When i had problem with boot it helped one things:
            1. Run RKAndroidTool.exe and before flashing EraseIDB
            or in additional after this step upload temporary different firmware that You tried to flash
            Wasser:
            I think You don't need to worry such thing, because the most people are greatful to You, people are different and even when You will give gold for everyone, You will find some unhappy people too(because it is to heavy or something)
              hello,
              about wifi problem, i saw logcat,
              it is reported wifi driver load error...
              PointerTracker( 534): -------- release old key ---------------
              D/PointerTracker( 534): -------- release old key ---------------
              D/dalvikvm( 1590): GC_CONCURRENT freed 399K, 42% free 4805K/8212K, paused 2ms+3ms, total 27ms
              D/dalvikvm( 368): GC_FOR_ALLOC freed 579K, 14% free 9962K/11504K, paused 57ms, total 57ms
              D/dalvikvm( 452): GC_CONCURRENT freed 1084K, 81% free 6142K/31336K, paused 2ms+4ms, total 28ms
              D/dalvikvm( 452): WAIT_FOR_CONCURRENT_GC blocked 26ms
              D/AudioHardwareALSA( 109): Audio exiting sandby will open audio device
              I/ActivityManager( 368): START u0 {act=com.android.systemui.recent.action.TOGGLE_REC ENTS flg=0x10800000 cmp=com.android.systemui/.recent.RecentsActivity (has extras)} from pid 452
              D/dalvikvm( 452): GC_CONCURRENT freed 122K, 79% free 6610K/31336K, paused 2ms+4ms, total 35ms
              D/dalvikvm( 368): GC_FOR_ALLOC freed 138K, 13% free 10067K/11504K, paused 50ms, total 50ms
              W/BufferQueue( 106): freeAllBuffersLocked called but mQueue is not empty
              W/IInputConnectionWrapper( 1590): showStatusIcon on inactive InputConnection
              I/qtaguid ( 368): Failed write_ctrl(s 0 10064) res=-1 errno=1
              W/NetworkManagementSocketTagger( 368): setKernelCountSet(10064, 0) failed with errno -1
              D/AudioHardwareALSA( 109): AudioStreamOutALSA::standby().....
              D/dalvikvm( 368): GC_FOR_ALLOC freed 309K, 14% free 9971K/11504K, paused 53ms, total 53ms
              D/BluetoothAdapterService(1097373104)( 811): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@ 4168aef0
              D/EthernetManager( 870): getEthernetIfaceState() : Entered.
              D/EthernetService( 368): getEthernetIfaceState()
              D/EthernetEnabler( 870): handleStateChanged: state:1
              D/EthernetEnabler( 870): BroadcastReceiver: Ethernet interface current state:1
              D/WifiHW ( 368): Read wifi chip type OK ! wifi_chip_type = RK901
              D/WifiHW ( 368): wifi_load_driver: DRIVER_MODULE_PATH = /system/lib/modules/rkwifi.ko, DRIVER_MODULE_ARG =
              D/WifiService( 368): setWifiEnabled: true pid=870, uid=1000
              D/WifiHW ( 368): wifi_load_driver: driver load failed
              D/WifiHW ( 368): Unable to unload driver module "wlan": No such file or directory
              E/WifiStateMachine( 368): Failed to load driver!
              E/WifiStateMachine( 368): DriverFailedState
              D/dalvikvm( 368): GC_FOR_ALLOC freed 506K, 14% free 9975K/11504K, paused 68ms, total 68ms
              D/dalvikvm( 368): GC_FOR_ALLOC freed 140K, 14% free 9965K/11504K, paused 62ms, total 62ms
              D/dalvikvm( 368): GC_FOR_ALLOC freed 135K, 13% free 10073K/11504K, paused 44ms, total 44ms
              D/dalvikvm( 452): GC_CONCURRENT freed 911K, 80% free 6514K/31336K, paused 2ms+6ms, total 44ms
              D/dalvikvm( 452): WAIT_FOR_CONCURRENT_GC blocked 41ms
              D/dalvikvm( 368): GC_FOR_ALLOC freed 325K, 14% free 9974K/11504K, paused 59ms, total 59ms
              I/qtaguid ( 368): Failed write_ctrl(s 1 10064) res=-1 errno=1
              W/NetworkManagementSocketTagger( 368): setKernelCountSet(10064, 1) failed with errno -1
              I/InputAttributes( 534): InputType.TYPE_NULL is specified
                Kernel Links
                Hello there.
                I´m trying to download the 1.2.5 firmware kernel, but the links (old and new) are broken.
                Someone can fix the links? Or someone can upload the kernels?
                Thanks for the help!
                Abraços do Brasil!
                  Please repair links! A bought a 2.1 Amper charger and i like to try OC kernels
                    Thank you
                    Many Thanks Wasser for your incredible work
                    My T-R42 (board v2.0) works perfectly now, much faster than with stock rom
                      Where do you download de files?
                      Do you install the old or the new kernel?
                      I cant download the kernels! The links are broken...
                        I downloaded it a few days ago (transportation from China was very very long !)
                        I used new kernel, 720p.
                          Please, can you upload only the kernel?
                          I have donwloaded the 1.2.5 firmware, but kernel links are broken...
                            Same here. This box works very smooth compared to stock ROM.
                              Originally posted by wasser View Post
                              first thanks for the feedback!
                              could you please download the new libmedia.so from the download url and copy it to /system/lib/libmedia.so, then reboot.
                              Please try to test again if the sound issue is fixed?
                              thanks
                              wasser
                              download url:
                              https://drive.google.com/file/d/0B3x...it?usp=sharing
                              hello I downloaded, first of all thanks for the quick response, and copied to the path that I've spent the. Upon restart, not just starting, stays on the bootanimation. I will re-flash your firmware again and I'll try and see if I have done anything more unintentionally. you'll have already reported.
                              Thank you.
                                I download wasser 1.2.5 stock rom, but kernel links are dead (please reload new or old links). I installed rom without kernel (in RKAndroid Tool I unchecked kernel square and install without kernel).
                                Will this be OK? Or I have to install with kernel. Can someone please explain what does it mean ROM installation and what does it mean Kernel installation? Is it possible to install ROM without Kernel?
