T-R42 - wasser firmware - JB Android 4.2.2
TVOut not workin, there is sound, but black screen just, how to fix it? im using 1.2.5 with newest kernel 720P k-rk3188-v3.5 board
here is remote controler fix for it http://www.androidsonline.eu/download/rkxx-remotectl.klLast edited by tashkas; 02 June 2014, 14:41.
1080p
Originally posted by mycheetah View PostYes it is for new revision, you could opt either 1080p or 720p kernel when flashing the rom, both also work great.
Originally posted by Tommya2004 View PostIf iflash with the 1080p kernel will i have the option to change to 720p output in settings ?
Flashing tool
Originally posted by mycheetah View PostYou can't change it in the Settings. Should you decide to change back to 720p after flashing 1080p, you need to flash ONLY the 720p Kernel in Finless Flash Tool ( only tick the kernel and point it to the 720p Kernel.img and then flash)
Originally posted by Tommya2004 View PostCan you give me a link to the flashing tool you use please
There are currently 1675 users online. 0 members and 1675 guests.
