T-R42 - wasser firmware - JB Android 4.2.2
I think you'll find what you need here : http://blog.geekbuying.com/index.php.../#.U1990aLC6ZQ
It's this firmware good for my R-BOX with ZXSD-Z X005 V02 board ? Thanks in advance for every advice !
LE : Can not upload jpg file (125k) ?!?
Originally posted by fratello View PostI think you'll find what you need here : http://blog.geekbuying.com/index.php.../#.U1990aLC6ZQ
Sound problem - 1.2.5 and kitkat 0.95 - both have sound cutting in and out issues
Hi Wasser, First of all, I want to Sincerely thank you for your hard work, dedication and for helping us out as well as adding excitement to our hobbies.
I have flashed 1.2.3 and 0.92 kitkat - did not work well for me (Wifi problems).
flashed 1.2.4 - ok but not perfect - sound problem and slow Wifi.
flashed 1.2.5 and 0.95 kitkat - running fast and smooth for both but the sound problem still persists.
I replaced libmedia.so as you suggested to another user but no luck.
I flashed 0.95 with the sound fix - did not boot.
The sound problem - randomly the sound would cut in and out constantly, for about 2 seconds (in 1 minute 10 to 25 times) with like a "drrrpp" sound (like when you plug a mic in).
TV - panasonic viera 50" 1080p (plasma).
T-R42 - B351_V2.0 - RK1000-S, RTL8201F, SKhynx chip.
Please help resolve this issue - i am pretty sure im doing something wrong as most people are not complaining.
UPDATE: i tried on LG 720p TV and it worked perfectly. I tried on pioneer 1325 amplifier..perfect. So i played with Panasonic TV sound setup thinking it may be the TV sound no change at all and ruled out TV as problem. I started playing with resolution on T-r42 (i initially flashed 1080p then 720p) changed to full 1080 ..sound problem..full 720P and same sound issues..then changed to the lower 720P (720 x 480..i think) and it almost disappeared, sound cut out once ..in every 3 to 4 mins. What could be the problem?
Thank you WasserLast edited by kingjay; 16 May 2014, 17:03.
Originally posted by gotpaste View PostAll, Has anyone had issues with the video staying in sync with the new firmware. I just purchased 2 t-r42 units and they seem to stay displaying video for a few minutes then the screen goes black and then reappears ...any thoughts that I can do to resolve this issue. I tried the old revision firmware and it did the same thing but then started working ok...but Bluetooth and wireless did not work....using the 1080p kernel and boot. It also seemd like there was artifacting during the boot when I first flashed it
Sceen keeps turning black every some seconds and then its back on. Endless loop. Also tested lewy rom same result. Did not find any solution yet. Anyone that can help please do
Boards V3.x
Estimated Wasser:
Of my colleagues are upgrading their T-R42 rom to your device, but apparently this geekbuying V3.X putting plates on the new models, so they are having compatibility problems.
Are you going to get any rom to fix at least compatibility with v3.2?
Thank you very much and best regards
Same problem here.Just got today a couple new T-R42 boxes and found out that there is a new boardversion B351_V3.2.
Spent half a day reflashing and wondering why it is not working properly with this firmware. Opened one up and there it was. Why did they have to change it again
Please Wasser, could you make your firmware work also on this board. This box is useless without your firmware. Here is a photo I made of this board
ROM FOR V3.2
Another colleague has posted freacktab me in another thread where download a compatible ROM V3.2 FOR PLATES.
I can say it works 100% tested 10 minutes ago.
Here I leave the link.
Greetings to all and see if wasser shows us a rom compatible with these plates.
There are currently 2490 users online. 1 members and 2489 guests.
