Bill
T-R42 - wasser firmware - JB Android 4.2.2
Re: T-R42 - wasser firmware
Originally posted by avg View PostHi Wasser,
my cs918 verison: RK3188-t 1.6ghz , b351 BT (wifi chip 8723)
now im using wasser version 1.2.5, everything is fine except dark/black screen problem~
i can't use 720p even 50z or 60z, many sparkle in the screen and dark/black screen for 1 second repeatly. youtube: https://www.youtube.com/watch?v=SI-5...ature=youtu.be
So i get better result at 1080p, but the dark/black screen for 1 second occasionally, can i fix it?
is there any solution to solve the dark/black screen and fix mac address? thank you very much ~
There are specific kernels for 720p & 1080p, rather than trying running a 720p kernel at 1080p and vice versa.
What refresh rate is your TV capable of?
Each TV has a set specification at which it can refresh the screen, typically 50hz. This can not be exceeded. The white dots dashing about the screen are image refresh synchronisation / timing errors caused by too high refresh rate or interference on poor connection / cable.
Sent from my Nexus 4 using Tapatalk
wasser 1.25 rom, 1080p kernel, 1080p rom,
Video Signal System 480i/480p(60Hz), 576i/576p(50Hz), 720p(50/60Hz), 1080i(50/60Hz), 1080p(24/50/60Hz)*1 Power Voltage AC 220V 50Hz Originally posted by rceccleston View PostWhich kernel have you flashed?
Originally posted by dobosz23 View PostHello.
I`m back to firmware 1.2.4 because this firmware has a problem - I use them a week and now have problem with sd card and wifi and player was more hot then normally.
Some 3188t chips might become unstable and have problems at frekv. higher than 1.4ghz, in that case its better to use 1.2.4 firmware.
Originally posted by galaxy View Post1.2.5 firmware is running at 1.6ghz cause it removes 3188t freq. restrictions so its running hotter but its faster than 1.2.4 which is running at 1.4ghz. On 1.2.5 you get almost 19k in antutu benchmark, on 1.2.4 around 17k.
@wasser, do you have a plan to fix the issue with the recovery soon?? haven't heard from you for a while. Currently we bricked our device on 1.2.5 when we tried to boot into recovery. possible issue with the rom, not the recovery itself since we tried 1.2.4 and cwm recovery with same issue. Thanks.
1.2.5, 1080 and OC kernel
Hi, I just installed 1.2.5 old-rev rom and 1080 kernel.
I'm quite loving it and thinking of flashing it on my new model as well.
1) On Settings - Display, I see there are no options for 1080p, only for 720p.
Is it because of my TV ? it's 37 inch.
2) the OC kernels, they are under the rom version 1.2.4 on the first post, will they also
work on version 1.2.5 ? (new/old ?)
Thanks !!!
as i see, this firmware still cant work normal with 1080i internet video streams and something wrong with keyboard, on stock firmware, numbers were working on default keyboard, on this one it don't work how to fix it? that means rockchip cant handle 1080I???? Archos video player crashes on it. why do i get capped one file upload via ftp to 30mb its ftp server default or firmware capped?Last edited by tashkas; 01 April 2014, 13:37.
I did the same thing ... Reload 1.2.4
Hello buhohitr,
I tested this and it does cause problems ...
I reloaded 1.2.4 T-R42 Old version which works fine ...
Then, I reloaded the 1.2.5 T-R42 Old version and it is working again ...
This does NOT seem to effect the K-R42 Version only the T-R42 old
Michael T.Last edited by michael2t; 03 April 2014, 17:56.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
But after that I can NOT load 1.2.5 T-R42 old version any more ...
So I am stuck on 1.2.4 old t-r42 until Wasser can fixes the issue ...
But You would have the Player working again ...
Michael T.
Bill
No ...
Hello Bill-ns,
I have no issues flashing ... that all works fine ...
it just will not boot 1.2.5 with the NEW system t-r42 old anymore ..
Then I reload the 1.2.5 t-r42 old version 1080p and it is working fine again ...
I had 1.2.5 T-r42 working fine until I went into recovery and the selected restart from the recovery menu ... then every thing stop working ... I had to Reload the Firmware to get the system back ...
thanks
Michael T.Last edited by michael2t; 02 April 2014, 16:39.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
thanks
Michael T.
wasser
Little info to flash wasser firmware
As you can see I registered to this forum today. I've been studying this thread for 3 days now (since I am waiting to get my T-R42 from geekbuying). Mainly I want to use the box for XBMC with 1080p.
I just need to know two thing,
1. Do I only need this :
firmware without kernel for B351_V2.0 :
http://www.freak-tab.de/wasser/firmw...sser-1.2.5.zip
2. and (steps to follow: when I get the T-R42 recognized in windows I open RKAndroidTool.exe and just hit Run)?
or do I need to know something else?
thank you for your support wasser and everyone
There are currently 2412 users online. 2 members and 2410 guests.
