T-R42 - wasser firmware - JB Android 4.2.2
    how to get back to droid OS
    hi freaktab
    after setup of this firmware I selected to always launch xbmc but once i do i have no idea how to get back to droid OS if i need to edit or do something on the droid os..
    is there a way to exit out of xbmc and get back to droid os..
    thanks
      webcam not working
      Hi Wasser,
      first,thank you for your work,
      Yesterday flashed the 1.2.5 fw on my T-R42 v1.0 (firmware without kernel for B351_V1.x ,and 1080p/720p kernels for old revision)
      Everything working, wifi,lan,bt, fast system speed,but the webcam not working. (Logitech C310)
      I used your older firmwares for the beginning,and my webcam always worked in Skype,and other camera app. (audio + video)
      This error can be corrected somehow? (put 1-2 files any system folder?)
      or reflash the 1.2.4?
      thanks,
      Z
      T-R42 v1.0 ; Ubox R89
        Bug in mount SD.
        I don`t know why but I have two times unmount SD and when I restart everyfing works fine - have you got that bug too?
          1.2.5 on v2.0 here. This is the most stable rom yet. Everything works except the logitec webcam. The webcam mic works but not the picture.
          Sent from my Nexus 5 using Tapatalk
            1.2.5 t-r42 2.0 board Video Sync
            All, Has anyone had issues with the video staying in sync with the new firmware. I just purchased 2 t-r42 units and they seem to stay displaying video for a few minutes then the screen goes black and then reappears ...any thoughts that I can do to resolve this issue. I tried the old revision firmware and it did the same thing but then started working ok...but Bluetooth and wireless did not work....using the 1080p kernel and boot. It also seemd like there was artifacting during the boot when I first flashed it
              Newbie
              Dear all,
              I'm a newbie when comes to flashing. I own a TR42 with wifi/bluetooth chipset AP6210. I understand that v1.2.4 is not able to download from the 1st page of this thread.
              I wanted to flash v1.2.5 but which files do I select and how the flashing going to be done? Appreciate your help and patience...
                Is there any instructions or video that show how flashing is done?
                  Version 1.2.5 - flashing of other firmwares etc.
                  Hi All,
                  found some time to try out some flashing on my T-R42 V1.0 with Wassers Firmware 1.2.5.
                  I discovered some interesting behaviour which I would like to post here to first get to know if
                  anybody else stumbled upon this and secondly, if so, I found a workaraound.
                  1) When trying to flash (newer or other) parts onto the device, in my case I wanted to have a working recovery image flashed, it did not finish with success. (See Example-Log below)
                  It seems as if after flashing the Device is shortly being disconnected from USB, restartet, but restarts in "Mask mode" instead of the needed one. Hence checking fails and finally the whole image flashing fails.
                  This happened for both, single file flashing and the complete Wasser Distribution.
                  When trying to restart the device it just went into black screen for a few seconds and then switched
                  off by its own.
                  2) When flashing an older Boot-Loader (e.g. Levy 1.20) it could be reactivated and all flashing went fine again.
                  Did anaybody else have these problems or did I do something wrong ?
                  Regards
                  makku
                  Logfile RKDevelopTool 1.37
                  16:45:37 283 INFO:Start to run
                  16:45:37 283 INFO:Start to test device
                  16:45:37 283 INFO:Test device OK
                  16:45:37 283 INFO:Start to download file
                  16:45:37 283 INFO: Start to download files to flash,backup offset=0x24000
                  16:45:37 283 INFO:Flash Start to download file to flash
                  16:45:37 283 Info:RKA_File_Download start,file=recovery,offset=0x14000
                  16:45:38 377 INFO: Download files to flash finished,Total(2893902)B
                  16:45:38 377 INFO: Start to check data
                  16:45:38 377 INFO:Start to check download data
                  16:45:38 377 Info:RKA_File_Check start,file=recovery,offset=0x14000
                  16:45:38 408 Error:Compare recovery file failed,Offset(0)
                  16:45:38 424 Error: Check system file failed
                  16:45:38 424 ERRORownload file failed
                  16:45:38 424 ERROR:Image Thread Failed
                  16:45:38 424 ERROR:Run failed
                  T-R42 V1.0 - Wasser Firmware 1.03 KitKat
                    Hi Guys...
                    I need some help. I am newbie with this so please go easy.
                    I have T-R42 V3.5. I downloaded this firmware and flashed with RkBatchTool. There were no error message and the flash process seems to have gone well. But now the Box wont boot up. When i start it, The blue light flashed for few seconds and that it switches it self off.
                    Any idea what might be wrong? Did i brick the box?
                      Hi I have flashed this box a couple of times with no problems. It flashes ok but now it wont power on and remain on . Any ideas. I don't even see a boot sequence. I can connect box to computer and hit button on back of unit and the loader tool recognizes the device.
                        Originally posted by Iru786 View Post
                        Hi Guys...
                        Please do not use RKBatch Tool, use RKDevelop Tool instead. You could follow the tutorial in http://wiki.radxa.com/Rock/flash_the_image
                        Scroll down to the section"Using RKAndroidTool to flash image by partitions" for step by step guidance.
                          Into recovery mode
                          I press and hold the recovery button at the back of the box, insert micro USB cable from PC to the box and plug in the power...Nothing happen... PC not detecting anything...
                            Just flashed this firmware but wifi and ethernet not working. In devive manager the driver is not working either. Code 10 Device cannot start.
                            Can anyone help a novice......?
                              May I know how do you flash the unit?
                                With the RK develop tool.
