T-R42 - wasser firmware - JB Android 4.2.2
Originally posted by wasser View Post
my gpio dump reported 128 pins in 4 banks. that sounds cool. uh uh what does that mean? the ethernet/wifi/bluetooth all do not work in my t-r42 from Amazon-Geekbuying with your 1.2.4 rombut wowee wowaa 1.2.3 works great! I guess the one-click RKBatchTool is the way go to for newbies like me.
the log files are attached. dmesg-gpio-wifi-off-bt-off.txt.zip
Thanks for the good work man!
Originally posted by petesimon View Postokay done. my board is B351_V1.0 in this photo http://i.imgur.com/DavJg4P.jpg
the log files are attached. [ATTACH=CONFIG]4923[/ATTACH]
Also where is link to Wowee Wowaa ROM?
I have a big problem to download on China site it is very low speed conection, if someone already has fw for Mk918 caled "update_cs918_203j2104_overseas" or "update_mk918_100k4100_beta0.1.img" please post it on a normal hoster or on this forum if possible..thanks a lot in advance...
links are :
Originally posted by gor View PostI have a big problem to download on China site it is very low speed conection, if someone already has fw for Mk918 caled "update_cs918_203j2104_overseas" or "update_mk918_100k4100_beta0.1.img" please post it on a normal hoster or on this forum if possible..thanks a lot in advance...
links are :
http://www.bee-link.com/en/article.php?id=98
Maybe due to you I lost my connection when I was in 70%...
I am trying to download newer one:
Originally posted by ollie26 View PostTry using the Old kernels from wasser rom..you should get either WiFi or Ethernet working then.
ThanksI'm laughing I"m laughing! haha. oooh I wish a ROM were called that name. I feel happy saying out loud "wowee wowaa rom". haha.
No disrespect or offense intended, but "wowee wowaa" is a spoken expression. Like "wow" or "cool". I think I got it from a movie or TV program. http://www.urbandictionary.com/defin...ow%20wee%20waa
I was really referring to wasser rom, version 1.2.3. and I'm really clumsy with correctly selecting 6 files in the RKAndroidTool. RKBatchTool is easy cheese. Cheers
Originally posted by petesimon View PostI'm laughing I"m laughing! haha. oooh I wish a ROM were called that name. I feel happy saying out loud "wowee wowaa rom". haha.
Originally posted by MattPaul View PostMaybe due to you I lost my connection when I was in 70%...
http://pan.baidu.com/s/1ntseorf
Originally posted by MattPaul View PostStill no luck downloading it - the connection cuts off in the half, about 5 attempts to download it already
__________________________________________________ ______________
This is for everybody who wants to successfully download from overseas far faaaar away file-hosting sites. (click on inline small photos for a larger view)
1. open the download website with a modern browser such as Chrome/Chromium or Firefox
2. click on the download link (complete any puzzles or download prerequisites)
3. let your browser download the file for just a few seconds
4. open the browser's "Downloads" tab
5. cancel the download in the browser
6. right-click and copy the http download link associated with the file you want, usually the one at top
-- link looks scrambled such as "http://qd.baidupcs.com/file/e88c7dee7037ac76e30ebb4d1c9d7cf3 ..."
7. open and command-prompt or terminal window
8. run wget or curl with the "continue" and "verbose" and "filename output" options (also like the "show server responses" option) and the download link enclosed in quotations
example with wget:
Code:wget -c -S -v -O output_filename.zip "http://link_that_you_copied_from_browser_here"
In the case of the cs918 download from baidu http://pan.baidu.com/s/1ntseorf I wrote up this complete command line. when the download finishes, you will get the file cs918_3188_8723_20140124.zip :
Code:wget -c -S -v "http://qd.baidupcs.com/file/e88c7dee7037ac76e30ebb4d1c9d7cf3?xcode=7e963061748542342544f224c77596e8170b3fed2f4b06b3&fid=2134144741-250528-3111670047&time=1390777574&sign=FDTAXER-DCb740ccc5511e5e8fedcff06b081203-Vn84QN1ljJmnIIMkjl5IGhGWKz0%3D&to=qb&fm=Q,B,U,ny&expires=1390785295&rt=sh&r=334816284&logid=856526391&sh=1&vuk=17093855&fn=cs918_3188_8723_20140124.zip" -O cs918_3188_8723_20140124.zip
__________________________________________________ _________________
More help: the manual page for wget and the manual page for curl
download wget for Windows (win32 command line) here or here. or try "curl" here.
Cheers
Originally posted by petesimon View PostYeah that happens to me when I download large file from mediafire, 4shared or similar. I'm a yankee and I have only a 1.5 Mb internet connection, so I must be patient sometimes. I use a kind of 'trick' to auto resume the download with wget or curl command line tool.
[ATTACH=CONFIG]4934[/ATTACH]
[ATTACH=CONFIG]4935[/ATTACH]
[ATTACH=CONFIG]4936[/ATTACH]
example with wget:
Cheers
Originally posted by ollie26 View PostAudio is problem for me too. Which kernel did you use? Also have you found a way to hide the taskbar?
I uploaded also to my T-K42 v2: kernel-t_r42_cpu1704_ddr720_1080p_gpu600h.img in 1.2.4 wasse's soft but i have no ethernet.
Could You advice what i did wrong?
Download link for firmware
Originally posted by buhohitr View PostSee if you can download from my Google drive:
https://drive.google.com/file/d/0Bxr...it?usp=sharing
Sry, I didn´t see your message - now after downloading and trying both firmwares I can say, that no one is working by me. I have the undefined board. I am posting my pic again of it, if anyone could help me, I would be very happy.
The only ROM which is working on it is the very old one 20131010. I am leaving it bricked with bootloops, don´t have much time for this now to flash the old one and set everything up when it´s still not usable for FULL HD playback...
I uploaded OFW kitkat (http://www.bee-link.com/en/article_cat.php?id=6) for my T-R42 v2:
update_A9_100k4100_beta0.1.img
I had hope it will be working because both run without problem, but no act on remote controller, mouse usb, keyboard usb or air mouse
There are currently 3828 users online. 0 members and 3828 guests.
