T-R42 - wasser firmware - JB Android 4.2.2
Hi All Im new to this but have been browsing forum for the last month or so. I received my MK888B (TR-42) and I find it a little buggy and Im willing to try custom ROM. The board is a B351_V2.0 2013/09/22
Questions on flashing
Rkandroidtool line 6 change file name to kernel-1080p-t-r42-new.img (? new or old)
line 5 change file name to boot-1080p.img
line 2 leave it as is
Hit Run icon
Im having problem installing 64 bit driver windows 7. At one point I had the driver installed and recognizing device. Ill try again.
Jesurun DX05 with bluetooth.
Hello wasser - thanks for new firmware. I used your version 1.2.3 end it`s work fine as long as i use game or app to touch driver as keyboard. It was reboot player over and over in three times. Maybe this version was stable to I can play. My Jesurun has call t-r42 v1.0 - is this correct? Witch version I can use - 720p or 1080p?
Originally posted by sebastianabate View Post1) Why on all of your roms the CPU is limited to 1.4 GHz? The stock kernel/rom works OK with 1.6 GHz
Originally posted by bill-ns View PostAny help on the lack of autohide system bar? The style that was included in previous versions worked well. If this isn't possible, any recomendations?
Originally posted by SANGER_A2 View PostHave you looked in the system settings? You can turn it off an on there in the older versions. My box is in pieces ATM so I can't check where - probably in the display section. I hope this feature hasb't been removed as it's a very useful feature in the 1.2.0 ROM!
Bill
Originally posted by mrsix View Post@svN89 try to flash old kernel.
Hey wasser,
thank you very much!!Guys..where i can find rkgamecontrolsetting.apk?!?
Here are some photos from the bord
I'm unable to get my device to be recognized by windows. The RK-tool cannot find it. I have 1.2.3 on my T-R42 box. When I hold down the recovery button and plug it to my pc, my pc does nothing and my box goes to the System Recovery menu. I even tried to use the me menu "Update rkimage from external storage". I have tried several times but no luck. Can anyone help?
Originally posted by adoga View PostThe RK-tool cannot find it. I have 1.2.3 on my T-R42 box. When I hold down the recovery button and plug it to my pc, my pc does nothing and my box goes to the System Recovery menu.
there's a settings.ini.
Inside you find:
SUPPORTUSB11=0
Try out:
SUPPORTUSB11=1
After hours of trying it works on my win8.1
There are currently 2121 users online. 1 members and 2120 guests.
