Sent from my HTCSensation using Tapatalk
T-R42 - wasser firmware - JB Android 4.2.2
Re: T-R42 custom firmware by wasser
Originally posted by vicolodo View Post
Sent from my HTCSensation using TapatalkMy Device: T-R42
ROM: Wasser ?????
Peripherals: 5Port USB-2 Hub : Logitech K700 Keyboard : Buffalo 1TB HDD : 32 GB MicroSD : Wireless Xbox360 Controller : 5amp switch mode power supply
wapvirus
Hello wapvirus,
Who's USB Camera Are You using with the T-R42 and is the Audio and Video working ???
I tested the t-R42 with the NEW Skype Inverted version (from Your Link) on the T-R42 player
and The new one on my phone ... I had to Play with it a bit, then the video just
started to Work ... I have no camera on the T-R42 only my phone ...I was sending video ...
I was Hoping to get a USB Camera with a Built in mic that Works with the T-R42 ...
Does Any one Have any good Recommendations???
Michael T.
Originally posted by wapvirus View PostTry this version it has many mods so it works on more devices
Sent from my HTCSensation using Tapatalk3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
hey guys,
today i ve got a t-r42 instead of a k-r42. i flashed wasser's newest rom sucessful. but the device doesnt give any signal through hdmi :/
the blue led lights up but i cant see anythingwhat goes wrong? i have tried to flash 1.2.2 with new kernel and new cwm in one flash but there is no signal also.
does anyone have the original rom as backup?
i can flash new roms to device. so it is not dead. but what should i do now? i am so dump :/ i should read about the ne version 2.0 before i flashed -.-
greetings
ok these are the files I dumped from the unit with the working LAN.
gpio_dump.txt gpio_dmesg_stock.txt lsmod.txt
the lsmod.log has been renamed to *.txt, If I didn't do something right please let me know and I'll redo it.
I also attempted flashing another box with the B351 V2.0 board and got a different result. Wifi works but BT and LAN don't which seems to be the same as everyone here.
Originally posted by EGM92 View Postok these are the files I dumped from the unit with the working LAN.
[ATTACH]4349[/ATTACH] [ATTACH]4350[/ATTACH] [ATTACH]4351[/ATTACH]
Originally posted by EGM92 View PostI don't have a C270 but I tested it with my C920 and it wouldn't start up, the LEDs turn on, the mics work, but the video image stays black.
i have C270 and it works fine (mic,camera, sound, video quality ...all is fine) when skype is able to open the window for the video call...
many times instead skype tries to open the window, then crashes and exit...this is my problem
many times instead skype tries to open the window, then crashes and exit...this is my problemMy Device: T-R42
ROM: Wasser ?????
ROM: Wasser ?????
Originally posted by vicolodo View Postok thanks ... which settings i have to adjust?
ROM: Wasser ?????
There are currently 1568 users online. 0 members and 1568 guests.
