T-R42 - wasser firmware - JB Android 4.2.2
Originally posted by EGM92 View PostWe're attempting to get the rom working on the V2.0 boards.
Originally posted by wasser View PostEGM92, thanks for your dmesg/gpio log! i think i have now enough infos to make v2.0 board working and hope to get new firmware done this week.
Originally posted by EGM92 View PostGreat if you need me to test anything just let me know, or if you need anymore dumps. What I find weird is that I could only get LAN working on one box, every other box that I tried I could get the wifi to work but not the LAN.
thanks
Android 4.4 KitKat.
Hello waser - are you working with new firmware on 4.4 KitKat?
I have your firmware 1.2.3 and work`s great, but I read is wi-fi signal is worst then stock firmware - is that true beacuse i don`t see any difference on display wi-fi strength in the bottom panel.
Sorry for my English - dobosz23.
Can the B351 v2.0 board stock FW from GeekBuying help?
All -- for those of you with the v2.0 board, the stock FW was release by GeekBuying as well as instructions on how to identify if you have onefrom geekbuing blog: "Check the back of T-R42, you will find a S/N number, if the S/N number start as T-R42, then means it is B351 V2.0 board, and you need the above firmware. if the S/N number start as BX, it means you have the B351 v1.0 board"
Maybe having the stock FW with kernel and drivers for all hardware nuances of this v2 board can be helpful to wasser on his custom kernel and FW.
I purchased my T-R42 from an aliexpress seller and it has not yet arrived, but good chances it will be the V2.0 board.
Originally posted by veclinux View Post
Can someone upload another link please?
from geekbuying blog: "Check the back of T-R42, you will find a S/N number, if the S/N number start as T-R42, then means it is B351 V2.0 board, and you need the above firmware. if the S/N number start as BX, it means you have the B351 v1.0 board"
I just received two T-R42s from geekbuying (Christmas gifts for friends).
These T-R42s look exactly as this K-R42 reviewed by geekbuying, only being black.
What exactly is the back of T-R42? Where is this serial number? Is it supposed to be on the empty sticker plate?
I think that I have to open them tomorrow to have a look inside if they are actually B351_V2.0.
Originally posted by EGM92 View PostIt's a B351 V2, I opened all my boxes the other day to make sure, I currently have 6 boxes, all of them are the new board.
Originally posted by loko View PostCan anyone please explain to me what does this mean?
How to open this device? Does it have screws under the pads?
hope that helps!!
anxiously awaiting Wassers new rom................
cheers,
Vec
There are currently 2270 users online. 1 members and 2269 guests.
