After a Lot of People having Trouble run my Hybrid Rom on this Device,
I decided to split it off.
Here is now the Custom Rom for all Versions off the MK809III,
This means it's run on Hardware Version 1,2,3.
This is a 720p Rom no 1080p at the Moment I need a Stable Kernel.
What is inside ?
A Complete Custom Rom for the MK809III without China Apps.
The RomĀ“s comes with a Patched Kernel for better Performance.
Also included are the newest WI-Fi Driver for Best performance.
*UPDATE*
What Software is included ?
Android 4.4 Fonts
Android 4.4 Boot Animation
SPMC Media Center (XMBC Fork)
Open Explorer
Netflix
SuperUser *fixed*
Terminal Emulator
Init.d Support
Added Support for the following:
NTFS
CIFS
XBOX Controller
Have Fun with my Updatet Rom for the MK809III.
After Flash on the First Run wait 3 Minutes before you Shutdown the Stick.
This is needed that all Software will be installed.
Download:
Kernel Links for different Kernels also include a 1008p Kernel.
The 1080p Kernel is kernel3.img.
Download:
Neomode
