Otherwise you can get weird behavior with the video playback.
NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
Originally posted by neomode View PostThe Kernels are overclocked.
The First is Stock DDR Clock and 1.6 Ghz
The Kernel one and two are DDR overclocked to 700 and 750.
The kernel 3 is a 1080 Kernel with 1.6 and DDR set to 650.
All Kernels have Video Fix.
The NTFS support is in the System not in the Kernel.
I am aware that the NTFS support is in the System and not in the Kernel, so it is better to user the 1.9a ROM to still have the NTFS Support + kernel1 (700) or kernel2 (750) ?...
Or may be is better the 700, for security reasons and to avoid overheat in my CX-919 that don't have any internal heatsink?
Do you think is secure to flash using one of these kernel only or is more secure to make a Full/Complete ROM Flash?
I also would like to know, only to compare, wich of these four kernel did you included in the 1.9a ROM Pack?
Thanks for always help with all our requets!!Last edited by ulises1954; 09 December 2013, 01:23.
Hello from a newbie!
I'd like to patch my MK809III, but I need a step by step guide for beginners like I am.
I really don't know how to start and from what. I only know that I need to open my device to get the reset button.
If somebody could post a link to a guide I'll really appreciate it.
Many thanks!
Re: NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
Originally posted by neomode View PostOK got you.
I personally think the Problem is that the PSU has not enough Power for the Stick and the
USB LAN Adapter.
Can you try one with 3A ?
Neomode
Sent from my MK809III using TapatalkMy Device: MK809III new Wifi Neomod Rom 2.0
AW: NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
Look at this maybe it's for you.
My Nederland is a little bit rusty
http://m.****.nl/itm/141041987592?nav=SEARCH&sbk=1
Neomode
Freaktab.com Developer
Originally posted by stayfunkey View Postdoes someone know where to buy a 3A 5V psu in the netherlands or online, can't find an online store nearby. don't wanna wait 3 weeks for a psu out hongkong ;-)
Please help to find problem with my mk809iii and a toshiba 23 full hd tv.. it works only if I set a 720*xxx resolution.. if not display have fresh error and stop it every tot seconds with a black screen.. then turn on again and the other tine black.. why???
Inviato dal mio GT-I9300 utilizzando Tapatalk
i have a mk809III rev3 i think... i use finless 1.6b 1080p kernel from the this firmware with this rom, works great except for wifi ( but i use lan anyway)
0 frame skipping, and finally a sharp desktop on my 1080p screen
Hi Gh0stw4lk3r,
Why usong finless 1.6 and not last one 1.9a? Did you try it? It's better 1.6? I think that my problem is caused by tv 23 full hd toshiba in fact with my aquos sharp 32 not issue detected... I don't understand where to modify tv setings..
Thanks in advance
mk809iii
Hi neo thanks for new kernel for 1.9 rom it is working fine wifi really strong and good download speed spmc working fine slight audio sync but no problem really. I can still only get 720p no full hd. I thought this kernel was 1080? still have popping sound even when audio set to hdmi passthrough, but when popping screen flickers so could be psu so will wait until i get a good 3A one
thanks for all your work
cheers
Styl3r
There are currently 1197 users online. 2 members and 1195 guests.
