NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
kernel with Frame skipping fix?
Originally posted by Beris View PostROM works fine, but video playback is worse than at the kernel of Sam321.(MK802IV,201307..)(translator)
I also have the problem of Beris:
I tried all of your kernel, but with these returned the problem of jerky video ... what I had resolved with the kernel of Sam321 (with Frame skipping fix)
p.s.: the rest is everything to place and all works: wifi, GUI and software of base are excellent !
help meeeeee!!!
thanks for everything!!!
(I apologize for my bad english)Last edited by mrfrr; 06 December 2013, 10:04.
AW: NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9
help meeeeee!!!
Neomode
Originally posted by neomode View PostHello
To question one I must test it by my self
Will report back.
Question Two
What File Format Your Harddrive has?
NTFS can be a Problem
Where become the Device his power?
Neomode
for first problem please check it, if I put cable into DCIN black screen , if I put in otg no problem ( for me this is not a problem if so I don't burn the stick).
For second problem, yes the hd 2tb is NTFS filesystem because I've archived there video files (bigger than 5 gb).
Yesterday night I've tried to reproduce a MKV of 16gb with external pen flash memory an with mxplayer it works but with video/audio blocking problems.
mk809iii
Originally posted by neomode View PostHello,
Please flash it with kernel3.img
This should work for you.
Regards
Neomode
thanks for all your work NEOmode
There is no module for ntfs inside.
This is needed to read ntfs.
Will see to find one and implement.
Neomode
There is no kernel3.img in the package?
also i had root with the default kernel, but after changing the kernels, root is lost.
I have the superuser app, but it says SU is outdated and needs to be updated, then get a error that SU cannot be updated.
i do see SU in system/bin, so everything is there, but no root.
Originally posted by Gh0stw4lk3r View PostThere is no kernel3.img in the package?
did you erase IDB before flash?
Originally posted by neomode View PostFor power on DC in not work can be a hardware failure. Will test it with my one.
Neomode
About NTFS module could I in while install a NTFS app or we need a module?
Thanks in advance
There are currently 3890 users online. 1 members and 3889 guests.
