NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
AW: NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
Originally posted by stayfunkey View PostDid the same (with sam kernel) but stuck in a bootloop?! Just spinning circles. :-(
This Device did not Accept other Kernels. This was the reason that I Split it from Neomode Hybrid Rom.
Neomode
The ROM does work but has frame stutter, NFS doesn't seem to work
I tried the ROM from my previous post and it works fine, but according to some with frame stutter.
I extracted the CIFS.ko and TUN.ko so maybe Neomode knows how to implement them in his ROM.
Probably we still need a nls_utf8.ko but this one was not in the ROM!? So couldn't get NFS to work
https://dl.dropboxusercontent.com/u/52853899/cifs.ko
https://dl.dropboxusercontent.com/u/52853899/tun.ko
I hope Neo comes to the rescue!!!! The matrix all over again
Originally posted by packetlos View PostI can report back that I have tested hardware version v3 with Rom 1.9a and the Sam321 1080p 1.8Ghz and 1400Mhz memory kernel version and it works brilliantly, I don't know if it is Neomode's magic in 1.9a or the fact the kernel is overlocked but this is the first time my problematic high bitrate video file that I use to test has played properly without stuttering. And HDMI pass through finally.Happy days....
thanks
Styl3r
I would greatly appreciate if you post the the link of the:
That you have used...
BTW, do you know if it works in the CX-919?
Thanks in advance for help?
Originally posted by ulises1954 View PostStyl3r thanks for the valuable information.
Any answer to my question?
Icons Display Problems with Other Launchers?
Hi Neomode,
Thanks for the latest 1.9a ROM that now is working a lot better with my X-919!!
I have noticed that the KitKat Launcher don't look and feel/work as Smooth like the original KitKat Google launcher:
-Main Screen don't have the little Screen Position Indicator "Dottet-Line" (at the bottom).
-Widget Screen is not the same.
I also installed ADWLauncher, KitKat Experience and the Original KitKat Launcher, but have noticed that some APP Icons and Names are always displayed to close to be read or not in the same line position.
In ADWLauncher and Kitkat-Experience, the "Menu-Bar" (at the bottom) and the Icon to select all the APPs are both missing, so there is no way to see the Window with all the installed APPs...
Apparently something have changed in the way this new 1.9a ROM, handles the Screens and Displays the APPs Icons, because all the Launchers that I have installed doesn't worked as should.
Thanks again Neomode for always helping us with all our requets!!Last edited by ulises1954; 08 December 2013, 03:56.
Originally posted by babnik80 View Post
Can I use the 1.9a ROM + this Kernel for my CX-919 V2?
How... Only changing the kernel?
It could be safe to use in my CX-919 - No OverHeat?
Originally posted by babnik80 View PostQUOTE=ulises1954;120059]Thanks for the Link.
I think,yes. But if someone else knows better can answer.
Is this the direct and correct link for the Hight Overclock Kernel?
I am a little worried about overheat problems with my TV Stick... Does anyone knows if this overclock kernel is safe to use with the CX-919 that apparently don't have any internal Heat-Sink?Last edited by ulises1954; 07 December 2013, 16:20.
There are currently 2083 users online. 0 members and 2083 guests.
