You can check it with any cpu id
NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
kernel issues
Had the same. Looks like only these kernels are doing magic. Additionaly I've lost an ability to flash any other firmware with the bootloader ver. <2.07, even using restore option from rkbatch tool
1 way is to flash the original kernel from the top post and wait until Neomode tides all up.
DOn't get upset
cpu frequency
Originally posted by nefas View PostGreetings, dear Neomode!
Really appreciate your job! Keep going! If I had money, I would donate it to support your deeds ))
For now I can support you only with the kind words.
I have some concerns regarding this update. Could you please add the kernel the standard CPU frequencies 312-1608Mhz and remove the cpu_minfreq and max_freq limitations. Also please, take a look at /mali400_utility/param. I saw some duplicates there. Is it in use, btw, or deprecated? In any case 533Mhz will greatly improve performance, and will not add too much heat. And the last one - I hear a strange poking sound from speakers time-to-time on the both MK809IIIs I flashed. Is it normal? A kinda reminder? )
Thank you much anyway!
I noticed absolutely the same problems and ask Neomode to check this but got no answer
Maybe now he takes a look on this because firmware settings are really strange.
This is the MK809III I received from Geekbuying on the 16th Dec 2013 I have tried the new this firmware but it does not work, then I tried a MK802IV firmware and all works fine, including the wifi and Bluetooth.
Top view, can someone tell me what that loose red wire is? I guess its a antenna but not sure.
Closer look at the NAND and wifi chipset
There is no metal heatsink but a heat spreader sheet.
Re: NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
Originally posted by Magnus33 View PostYou guessed correct with the red wire.
Which MK802IV firmware did you use?
There are two different chip-sets and only the newer one uses this rom.
The older one uses a different driver so wifi would not work using this rom.
I'm surprised GB still has MK809III units with the old RTL8188 wireless...
Sent from my XT925 using TapatalkPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
It was the http://www.freak-tab.de/neomode/MK80...1_20130620.zip I used. I am surprise myself. I guess the kernel has driver for both wifi chipset.
Sent from my XT925 using TapatalkMk802IV Neomode 1.9a original rom 720p
CX 919 ROM / Overclock
Originally posted by Ozmosis View PostHi,
I have the CX 919 II (the black one with two orange wifi antenna)
Sorry im a little lost with which version to install... compatability etc
Am i okay to get the 1.9a package and inc kernal?
wish I had bought that stick..... mine is MK809 iii - alot of trouble finding an overclockable FWMK809III new Wifi Neomod Rom 1.9a - video stutter with mp4 / 264
AW: NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
Yes you are right Version 3 of this Stick is very buggy. I have a lot of problems to find a Working Kernel. I think it is maybe a Ram problem. Everytime I want go ever 400 Mhz it will not work.
Neomode
missing codecs
Originally posted by neomode View PostYes you are right Version 3 of this Stick is very buggy. I have a lot of problems to find a Working Kernel. I think it is maybe a Ram problem. Everytime I want go ever 400 Mhz it will not work.
Neomode
Havent given up - right now looking at another ROM : know this?:
MK809III_root_AP6210_20131022.zip
seems to work - now I will use the tools
rkpatchomatic (to fix video and OC)
first with the ROM included - then with a kernel i think is stock - but not sure... it is from the one in your post that wasnt new anyway LOL....
Thanx for your great work - and I WILL donate - and hope to contribute... would like to reach the results from zetzzzz but our roms arent compatible - wifi differsMK809III new Wifi Neomod Rom 1.9a - video stutter with mp4 / 264
There are currently 1641 users online. 1 members and 1640 guests.
