NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
    Originally posted by Magnus33 View Post
    Basicly two options here i think.
    Bad cable or adapter..happens and when they go its complete.
    Or bad device and i aviod the suppler because thats a odd failure to happen twiece.
    I have just tryed with 2 different leads, and another psu, and still the same.
    Originally posted by blinkone View Post
    Have you tried other roms. & always make sure you erase IDB (nand) befor flash
    http://www.freaktab.com/showthread.p...rs-with-AP6210
    Yep, i have tryed with other firmware including the above, and still the same.
    Think i might call it a day, and buy a media box, as my old sumvision never failed no matter what i flashed it with, just that i wanted something smaller and compact.
    ***********UPDATE**********
    I have just gone work and plugged it into a tower pc, and it now boots up, obviously the two psu's i have at home are not powerfull enough.
    So back in the game againtime to look for a decent usb psu
    Thanks for the help guys
      Dear Neomode,
      thank you so much.
      Will this work with MK802IV (new wifi chip) as well??
        Re: NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
        Originally posted by Rkman View Post
        Dear Neomode,
        thank you so much.
        Did you read posts here?
          Originally posted by neomode View Post
          @all an Update off the Rom is on the way. I need Testers please to get the best user expiricen. Thanks a Lot.
          Neomode
          Hi Neomode
          If you still need testers I am in, and will be glad to have a link for the files!!
          Basmand
            Will this work with new wifi chip ??
            Read the Thread´s Name ? AP6210 = New WIFI Chip !!!
            ... TVDroid
            > > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
              External HD suddenly unmounts
              Hello,
              I've been using this fantastic firmware for the last weeks and everything works ok, but I'm finding some troubles when trying to play HD movies with MPlayer and external HD. The movie starts to play and suddenly the HD unmounts and then remounts automatically.
              I suspect that this could be caused by poor PSU power, as the HD is powered through USB port... anybody else with such behaviour?
              I've got a S400 Cozyswan.
              Thank you very much.
                Any news on when the update will be with us neomode
                  Everyone is patiently waiting
                  Sent from my SAMSUNG-SM-N900A using Tapatalk
                    This Week when all Trolls gone away from the Rom
                    Neomode
                      Neomode
                      Take your time, Neomode and big thank you
                        Neomode
                        Did you found anything about the gpu oc problem on mk802iv stick(latest s/n)?
                          HDMI CEC
                          Hello,
                          I'm using rikomagic mk802IV with ap210 wifi with this rom. Is HDMI CEC available ? I cannot find this option ...
                          Grato,
                          Jairo
                            Two bad power supplies..your having not luck at all.
                            I sometime back went and got a unversal one with changeable heads to aviod this problem.
                            Mk802IV Neomode 1.9a original rom 720p
                              No ignore that, just tryed to switch it back on and nothing again, yet it does switch over to the hdmi channel, so cec is working within the stick.
                              Going send back for credit and invest in a different unit as im on the 3rd stick now, somthing not right
                              Thanks again for all your help anyway.
                                Your the victim of a long long little know family curse.
                                The witch that cursed your family back then was apparently specific in that it only affects android sticks
