NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
Both of you have the trim version of the cpu which requires something that missing from these kernels to get the full freq range.
We know it does so this since i tested it with stock to find out if it was hardlocked which thankfully its not.
Neomode knows of this now and if i remember correctly is working on the mk802IV now so we should see a rom with full range in short order.Mk802IV Neomode 1.9a original rom 720p
Originally posted by saschah View Postfirst...sorry for my english
i think i have the same stick....in every rom doesnt work wifi and bt but i found a rom that works...
download this
than unpack
go to folder RK Upgrding Tool -> Batch Tool
start the exe with admin
(on the left side you can change the language to english )
chose the file Update_bt919_rk3188_dongle_ap6210_131123.img (you have downloadet it first)
than press restore...
wait .....when it finished wifi and bt works....
p.s.my chip is this
http://tapatalk.com/tapatalk_image.p...ZW15aC5qcGc%3D
With this rom wi fi and blue too work verywell.
But this rom have too low fashion comparate with neomode romthe icon i too big and the power off bottom dont work just screen off. With neomode rom the stick power off.
For the other 3d game work well and streeming hd run dry! I feel much happy now but hope that anyone find the way to work wi fi and bluetooth with neomod rom!
Thanks saschah!
Guest
Installed on my CX-919 (April, 2013 manufacture date) and Root Explorer constantly crashes on me.
Also happens with other downloaded apps, as well.
Any fixes for this?
Edit: I had updated apps that required an update, after pre-install, and apps don't seem to crash now!
In Kernel zip, there are 4 kernel files: Kernel, Kernel1, Kernel2 and Kernel3? Is there a specific one the is 1080p native, or are all of these capable of 1080p? I used kernel1 and kernel (at different times, of course) and, from my experience, I was able to change it to 1080p - from 720p - unless there is a difference with those kernels. Any information on those would be appreciated.
Thanks!Last edited by Guest; 24 January 2014, 03:21.
Originally posted by Magnus33 View PostBoth of you have the trim version of the cpu which requires something that missing from these kernels to get the full freq range.
Originally posted by KolyaIsAwesome View PostInstalled on my CX-919 (April, 2013 manufacture date) and Root Explorer constantly crashes on me.
Any fixes for this?
Thanks!
Originally posted by ulises1954 View PostNeomode Can explain you better, but he already said in another post that:
Kernel is the Normal 720p Kernel.
Kernel1 and Kernels2 are Overclocked 720p Kernels.
Kernel3 is the 1080p Kernel.
I am using the Kernel2 with my CX-919 and all works flawlessly!!HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by hj0102 View PostThanks for great work, Neomode!
Could you add eGalax driver on Kernel? below is from google search. Lilliput 669GL touch screen is not properly working on android.
I am not developer and taking too much time to mod kernel and failed. Thanks.
Aaron
https://groups.google.com/forum/#!searchin/android-x86/dirty/android-x86/uNo7a39-s3I/SmmoFnJGaTkJ
RDG wrote,,
I added the following code to the hidinput_hid_event()
function in kernel/drivers/hid/hid-input.c:
--- hid-input.c 2011-11-28 18:27:46.237516103 +0100
+++ hid-input.c.ori 2011-11-11 11:45:38.000000000 +0100
@@ -782,18 +782,6 @@
if (usage->type == EV_KEY && !!test_bit(usage->code, input->key) !=
value)
input_event(input, EV_MSC, MSC_SCAN, usage->hid);
-//+RDG: patch for eGalax touchscreen: swap X and Y, invert X
direction
-if (usage->type == EV_ABS)
- if (usage->hid == HID_GD_X) {
- usage->code = 1; // vs 0 (X becomes Y)
- value = 4096 - value;
- } else if (usage->hid == HID_GD_Y) {
- usage->code = 0; // vs 1 (Y becomes X)
-//printk("RDG: hidinput_hid_event: type = %d, code = %d, value = %d
(hid = 0x%x)\n", usage->type, usage->code, value, usage->hid);
-//-RDG
input_event(input, usage->type, usage->code, value);
if ((field->flags & HID_MAIN_ITEM_RELATIVE) && (usage->type ==
EV_KEY))
how can i change the model that i could download more apps from google play?
Originally posted by neomode View PostHello MK809III Users,
After a Lot of People having Trouble run my Hybrid Rom on this Device,
I decided to split it off.
Here is now the Custom Rom for all Versions off the MK809III,
This means it's run on Hardware Version 1,2,3.
This is a 720p Rom no 1080p at the Moment I need a Stable Kernel.
What is inside ?
A Complete Custom Rom for the MK809III without China Apps.
The Rom“s comes with a Patched Kernel for better Performance.
Also included are the newest WI-Fi Driver for Best performance.
*UPDATE*
What Software is included ?
Android 4.4 Fonts
Android 4.4 Boot Animation
SPMC Media Center (XMBC Fork)
Open Explorer
Netflix
SuperUser *fixed*
Terminal Emulator
Init.d Support
Added Support for the following:
NTFS
CIFS
XBOX Controller
Have Fun with my Updatet Rom for the MK809III.
After Flash on the First Run wait 3 Minutes before you Shutdown the Stick.
This is needed that all Software will be installed.
Download:
Kernel Links for different Kernels also include a 1008p Kernel.
The 1080p Kernel is kernel3.img.
Download:
Neomode
2nd how can I change the name of the device that i will have the posibbility to download all smartphones apps from google play
Originally posted by code_blue View Post1ST let me thnks you for you work ! so THANKS
I use exposed framework from XDAdevelopers (search internet) first install exposed then all the modules including the one that fix Google play. It is fare the best way to do it, there are also many other modules that helps you increase your stick performance
PS!!! you don't have to change name on stick
Basmand
Thanks I will give this a chance
PS!!! you don't have o change name on stick
Basmand
Thanks man .
Ariel
There are currently 3142 users online. 0 members and 3142 guests.
