NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
Originally posted by vegarRingdal View PostPlease consider making a Donation to freakTab
Originally posted by vegarRingdal View Postno I didnt erase anything, just click run, does it matter?Please consider making a Donation to freakTab
Originally posted by vegarRingdal View PostI used the neorom flash tool...Please consider making a Donation to freakTab
Originally posted by blinkone View PostOk you should always erase IDB (nand) befor you flash a rom as bits from the old rom may still be three & course a bad flash boot errors..so when ever you flash new rom always erase the IDB first ..you don't need to erase if your just flashing the kernael though
tried one more time, this time "erase IDB", but same issue.
Like a endless boot :-(
so annoying, anyone here really good at using my working room and making it better?
Originally posted by vegarRingdal View Posttried one more time, this time "erase IDB", but same issue.
so annoying, anyone here really good at using my working room and making it better?Please consider making a Donation to freakTab
I'm trying to overclock the 1.9a but it looks like it's impossiblei used rkpatchomatic and it boots, but it shows only 1200min/1200max in SetCPU... if i use sam321's kernels it bootloop... How can i OC my MK809III ?
By the way, great work Neomode!
Overclocked Kernels for Neomode's roms -> [KERNEL][AP6210] Overclocked kernels for Neomode ROMs (2.1/2.0/1.9a/1.7)
I believe every neomode after 1.7 is a none over clocking rom with the exception of the new mk802Iv beta.
So its either use 1.7 or the new beta which is perfectly stable.
Although you may want to use the perimater file from 1.9a instead of the one the beta comes with since that hasn't been changed beyound the normal small sock size.Mk802IV Neomode 1.9a original rom 720p
Originally posted by Magnus33 View PostI believe every neomode after 1.7 is a none over clocking rom with the exception of the new mk802Iv beta.
By the way, in this post http://www.freaktab.com/showthread.p...l=1#post128558
babnik80 claims he did it, but TVdroid, says that the same kernel gives him the same problems i have...and it leaves out all the possible problems caused by different frequencies, resolution, etc... so, there must me something different to touch :/Overclocked Kernels for Neomode's roms -> [KERNEL][AP6210] Overclocked kernels for Neomode ROMs (2.1/2.0/1.9a/1.7)
Originally posted by vegarRingdal View Posttried v 1.9 and 1.9a with 2 different kernel.
But the rom above the wifi and bluetooth actually works
Anyone else know what wifi I got? mine looks just like the picture
Whats the chance we can add the driver to neomode custom rom.
Originally posted by okey View PostWell i got my wifi working using the below link and creating your own kernel, follow Zetzzzzz instructions and it should work.
http://www.freaktab.com/showthread.p...ighlight=bt919
Well thats good news.
I only tried to download one and test, did you extract the kernel from this rom:
http://www.sendspace.com/pro/dl/7bzbci #post 480 by saschah?
If you did, is there a chnace you could upload it so I can get it?
Still it would be great if neomode could add our chipset drivers to his kernel, if thats possible (I dont know stuff like this).
Thx
Thx
use it with "Finless 1.6b" i will upload mine now
Let me know if it works
I just tried to patch my kernl woth the overclock, but getting errors like:
CPU profile table cpu1800h is larger than the CPU table in the kernel
anyway I can read out something like that?
There are currently 3873 users online. 1 members and 3872 guests.
