Buy a new PSU. I'm willing to bet youve got a current bottleneck right at the supply. If the charger / PSU is rated for less than the current you try to draw through it, the PSU will eventually fail, causing system instability and eventually a restart.. Is the BB charger hot when the device restarts?. Consider 2A to be the nominal requirement for driving a stick.
Good luck n happy modding!
Sent from my Nexus 7 using Tapatalk
