NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
    Originally posted by okey View Post
    Yes it was extracted from the link you mentioned, and patched,
    use it with "Finless 1.6b" i will upload mine now
    Let me know if it works
    thx, still think its weird I got those errors when I tried to patch, we basicly used the same kernel..
    Will try you kernel one day, atm the finess 1.6b link is down here:
    Also ordered a usb to ethernet today, maybe neorom works with that, if it does than thats ok, wanted a wired network anyways :-)
      Try the link below, i have uploaded it on there, and within the kernels is my kernel i used, look for "kernel_vsfsam_cpustock_gpu798h_ddr800.img"
      https://www.mediafire.com/?acj793mju8t2p66
        Can't download
        I'm getting Error 403 (forbidden) when I try to download from freaktab.com. Any mirrors to download the ROM and kernels from first post? Thanks!
          Bob roms were deleted by a nasty former member but they have backups which they are restoring.
          Others here should have the roms stored and ready to pass on.
          Mk802IV Neomode 1.9a original rom 720p
            Awww... Thanks for the heads up.
              anybody experience with using it on a MK908ii? Looks like the same HW to me...
              MK908II T
                Hi Okey!
                I have the same device you have. Is this a 1080p kernel? (I am looking for 1080p rom/kernel where the wifi and bt works.)
                  Hi all, I'm a newb and been looking for a set way to re flash a device the correct way, after 2 days of no replies, I am attempting to do it myself on my mk809iii. I downloaded neos files in this thread, and when I run RKDeveloper Tool. I get "MSC cant do erase IDB" When I try to erase. It says on bottom it found Android Mass Storage device, so i assume all is well here. I have the device plugged in the mini USB port with the little usb symbol by it. Blue light is on. After erase I assume I was going to point it as the Flash in the develop folder, I don't know what the "File" file is for. After this I assumed again that I go to the next tab and flash the kernel? and I don't see erase on this page so we just overwrite it?
                  I'm really kind of lost but my 2 requests on doing this the right way with a guide have gone un answered.
                  Thanks for any help you can throw my way.
                  HighRise
                    Hi
                    is this rom suitable to the new CX-919 device?
                    the one with T CPU and probably the new WIFI Driver...
                    i tried the NEOMODE HYBRID ROM 1.7 and when i installed the 1080p kernel WIFI stopped working.
                    is this rom with kernel3 will work fine with my new CX-919?
                    i really want to install 1080P kernel and to be able to use WIFI...
                    thanks!
                      MK902
                      Hi Neomode,
                      Can you make the 1.9 with a kernel for MK902. I´m using your rom wih the kernel from cloudnetgo cr11 and its great.
                      For all your computer problems...
                      http://www.salvamipc.es
                        root
                        Hi
                        How would I go about if I wanted to remove everything related to root on this rom?
                        Is tun.ko loaded by default on this rom btw?
                        Go a application that I wanto use but it must belive that rom is not modified or rooted, else it wont work, hide my root and exposed rootcload will not help me.
                          Does this firmware has CWM Recovery included?
                            i want more speed for this rom.. what kernel you recommended? :P
                              Originally posted by smic717394 View Post
                              Hi Neomode,
                              I use the same combo, kernel is slightly overclocked. It is stock kernel not blinking on any device.
                              It would be nice to have some custom kernel of Sam321 for example working on mk902 and not blinking. BTW my mk902 now works on CPU:1.7GHz, GPU:800MHz, DDR: 667
                                Hi tobr,
                                do you mean that you are using an overclocked version of kernel from stock rom for cloudnetgo CR11S, flashed on Neo 1.9a and with a RK3188-T?
                                Have you used phjanderson's tool for overclocking?
                                Thanks for your attention.
