NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
    Originally posted by Magnus33 View Post
    Your the victim of a long long little know family curse.
    The witch that cursed your family back then was apparently specific in that it only affects android sticks
    pmsl, I am convinced that other people must have this similar issue, as i have had 3 of them all from different suppliers and all end up the same.
    A new firmware may cure this so will still keep one to one side and keep trying.
      Hope we will see Netflix HD support in the new Neomode's build and no stuttering issue… :-) as well as fixed 1080p launcher….
      Sent from my SAMSUNG-SM-N900A using Tapatalk
        Have you tried the restore fuction with the stock lader and firmware?
        Mk802IV Neomode 1.9a original rom 720p
          not sure wot u mean by restore function sorry
            If I use a USB LAN adapter, can I use this rom even though my stick is equipped with the old wifi chip?
              AW: NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
              You can try it because I included some Drivers for USB to LAN Adapters.
              Neomode
                driver
                Neomode
                Is there a driver included for the Asix AX88772 chipset,
                bought this adapter to replace my rd-9700 adapter
                My Device: MK809III new Wifi Neomod Rom 2.0
                  Continuing on the saga of the issues i have.
                  I work in a tv shop, so today had chance to try on other tvs, and i have now narrowed my problem down.
                  With 19.a (tryed all kernals as well), it will work with no problems on samsung, sony, lg, BUT i have tryed 4 different panasonic tvs, and i get no signal on hdmi
                  could anyone shed any light on this, as the stick works, just not on a panasonic
                    panasonic
                    No problems on my Panasonic TX-P42ST50 plasma, 720p kernel.
                      I am lost then, i have uploaded some photos of my stick, just wondering if i got some kind of different ones from you guys.
                      Number on board is "mk809iii_v1.0_20130606"
                        Hi
                        I know that you have got an answer but also no problem on my Panasonic TX-P50U30E plasma, 720p kernel.
                        Sorry I am on MK802IV and I can see that you are onMK809
                        Basmand
                          Just to confirm that i am doing this right.
                          clicking Rkandroid tool.exe, its found usb, eraseIDB, then run.
                          Is that right
                            Is that right
                            H
                            Yes, that's the way I am doing it work every time!!!
                            Basmand
                              http://dx.com/p/usb-2-0-10-100mbps-r...r-dongle-34691
                              Yes, I have that chipset and I can confirm that works quite well.
                                Hi all,
                                About the oc problem with the mali on mk802iv, Neomode i found a link to the new mali driver.The link is http://malideveloper.arm.com/develop...device-drivers.
                                This could sovle the problem? Is this driver already in your kernels?
                                Can you compile a kernel with this driver?
                                Thanks!
