cheers!
NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
well, i had my new one sent yesterday as my other one had no hdmi out after flashing, but it would flash no problem which was very strange.
I have used the 1.9a version with original kernel in the zip file, and it works fine, but a few problems i have.
1. If i set to 1080p i get faint intermittant horizontal lines on the screen including main menus, but 720 is fine (not a major problem)
2. Videos on xbmc are a bit jumpy, but that could be down to what version of xbmc i have installed.
3. The wireless keyboard/mouse loses connection then i have to pull the usb dongle out then back in, then it works again.
Also i installed custom flycast firmware, but got horizontal lines intermittant no matter what resoloutin i was set to.
Your reply's please
Originally posted by neomode View Post@all an Update off the Rom is on the way. I need Testers please to get the best user expiricen. Thanks a Lot.
Neomode
Anyway I'm going to order 2 more pcs (of shit) from the same supplier, then will have ability to test the new Beta.
You're doing great! Keep up the good work.
Cheers!
WBR, Nefas
Neomode
Cheers
Had statering issue with the 720p kernel on mk809 iv with the latest wifi. I tried to use 1080p kernel and problem went away. The only problem i see so far with the launcher. It does not display properly with the 1080p kernel.
Neomode please fix this in your next release. Thank you.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Originally posted by mymkv View PostHad statering issue with the 720p kernel on mk809 iv with the latest wifi. I tried to use 1080p kernel and problem went away. The only problem i see so far with the launcher. It does not display properly with the 1080p kernel.
same here, workin ok with 1080p kernel.. others makes video flicks or slow..
icons and text pretty small.. better with 720p kernel, but bad video..
Also one suggestion. Maybe you could have 2 separate download links for the roms in this thread. One for the MK809III and the other one for the MK809IV with the new WIFI. I know you separated them but it seems like both models are discussed in this threadnot just MK809 IIIā¦
There are currently 3611 users online. 1 members and 3610 guests.
