NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
    Originally posted by clercqer View Post
    I have made a dmesg logfile but as I'm completely unfamiliar with them, I have no idea how to find the info you described.
    Here is the logfile, could you take a look at it and tell me which chipset is in the adapter please?
    [ATTACH]4726[/ATTACH]
    You have SR9700 adapter, but the log dont write usb version. Your dmesg not a standard. I think, your device have some error, but Im only a user, not a programmer.Here is pair of line from my dmesg:
    <6>[ 3.894115] ASIX USB Ethernet Adapter:v4.1.1 10:06:04 Nov 22 2013<6>[ 3.894124] <6> http://www.asix.com.tw
    <4>[ 3.894167] ----> axusbnet_probe 1276:bind ASIX AX88772B USB 2.0 Ethernet
    <4>[ 3.894201] eth%d: status ep1in, 8 bytes period 11
    <6>[ 3.894555] eth0: register 'asix' at usb-usb20_otg-1, ASIX AX88772B USB 2.0 Ethernet, xx:xx:xx:xx:xx:xx
      New Version is out !
      Neomode:-)
      Thank you all for helping me to make a better Rom !
        Thank you, Neomode
        Sent from my SAMSUNG-SM-N900A using Tapatalk
          Originally posted by neomode View Post
          Hello MK809III Users,
          After a Lot of People having Trouble run my Hybrid Rom on this Device,
          I decided to split it off.
          Neomode
          Hi Neomode ,
          Thanks for your on this ROM ! It was the only one that would install and work on my stick....
          Not sure what model my stick is, but here are some pics:
ID:	431794Click image for larger version
ID:	431795Click image for larger version
          I noticed some issues with videos:
          1) When a videos plays it looks like the HDMI connection is interrupted. I used a xvid video from a Windows share folder using MX Player and BS Player using CIFS Manager. When the same file is played from either an attached USB Flash drive or the Internal SD , it fails to play at all - very strange .
          2) Youtube streaming also has the same issues, the screen goes black, the HDMI port and resolution status bar flashes on my Vizio HDTV and video starts again.
          The interruptions occur every 3 to 5 mins. , otherwise the videos play with very good quality !
          Some other related symptoms:
          1) Same HDMI connection loss happens on on some apps including Settings.
          2) The image on the taskbar on the bottom sometime flickers at the top of the screen
          3) in some apps (ex: from ES File Manager) a few pixel from the top line look compressed:
          I'm using the stock kernel.img and tried with both 720p and 1080p resolutions. Experimented with the kernel1.img , kernel2.img and kernel3.img versions as well - same results.
          Could this be an issue with the video frequencies being unstable or some HDCP/DRM copy protection scheme? Also by lowering the DPI to about 140 seems to lessen the interruptions.
          P.S. does any one have a clue what the real model # is and where I can find the stock ROM for this stick?
          Stupid of me not to make a backup before flashing !
          Info from the original ROM :
          Vendor Software:
          RK3188_R-BOX_ANDROID4.2.2-SDK_V1.0.0.130514
          Build:
          rk31sdk-eng4.2.2JDQ39eng.ant20130905.174416testkeys
          Kernel:
          3.0.36+ ant@adminroot-X9DRL-3F-iF#281
          Thu Sep5 17:43:16 CST 2013
          Thanks in advance for anyone's help !
          Update:
          This is like playing Goldilocks and the Three Bears
          Finally found a ROM that works without too many issues :
          NEOMODE HYBRID ROM 1.7 - MK802IV, UG007B, CX-919, MK809III and others with AP6210
          Jerky streaming video after a few minutes of play, but that could be a wifi problem that needs to be debugged!
            Thanks a lot neomode. I'll give 2.0 a spin when I get back home from work.
            Verstuurd vanaf mijn GT-I9100 met Tapatalk
              Bricked?
              Hi Team,
              I have got MK809III and was going to use this firmware. I did Erase IDB, went fine. Then I clicked Run and it started uploading some data. After a big file was uploaded it said that cannot find IDB file.
              Now it says same no matter what I used. I tried RkBatchTool (from Rescue package) and it says:
              12:04:27 168 Rockchip Batch Tool v1.7.1.1 start run
              12:04:52 320 **********Upgrade Start Total<1>**********
              12:04:52 321 <Layer 2-1-6> Test Device Start
              12:04:52 324 <Layer 2-1-6> Test Device Success
              12:04:52 325 <Layer 2-1-6> Check Chip Start
              12:04:52 326 <Layer 2-1-6> Check Chip Success
              12:04:52 327 <Layer 2-1-6> Get FlashInfo Start
              12:04:52 328 <LAYER 2-1-6> INFO:FlashInfo: 0 0 0 0 0 4 4 0 28 0 1
              12:04:52 329 <Layer 2-1-6> Get FlashInfo Success
              12:04:52 331 <Layer 2-1-6> Prepare IDB Start
              12:04:52 331 <LAYER 2-1-6> INFO:CS(1) (0MB) (SAMSUNG)
              12:04:52 362 <LAYER 2-1-6> INFO:FindBackupBuffer-->No Found Tag
              12:04:52 363 <LAYER 2-1-6> INFO:FindBackupBuffer-->No Found Tag
              12:04:52 364 <LAYER 2-1-6> INFO:FindBackupBuffer-->No Found Tag
              12:04:52 365 <LAYER 2-1-6> INFO:FindBackupBuffer-->No Found Tag
              12:04:52 366 <LAYER 2-1-6> INFO:FindBackupBuffer-->No Found Tag
              12:04:52 366 <LAYER 2-1-6> ERROR:PrepareIDB-->Loader-->No Found IDB
              12:04:52 367 <Layer 2-1-6> Prepare IDB Fail
              12:04:52 368 **********Upgrade Done Success<0> Fail<1> Time<46>ms**********
              12:05:00 485 **********Restore Start Total<1>**********
              12:05:00 486 <Layer 2-1-6> Test Device Start
              12:05:00 488 <Layer 2-1-6> Test Device Success
              12:05:00 489 <Layer 2-1-6> Lowerformat Device Start
              12:05:01 492 <Layer 2-1-6> Lowerformat Device Success
              12:05:01 493 <Layer 2-1-6> Test Device Start
              12:05:01 495 <Layer 2-1-6> Test Device Success
              12:05:01 495 <Layer 2-1-6> Check Chip Start
              12:05:01 497 <Layer 2-1-6> Check Chip Success
              12:05:01 498 <Layer 2-1-6> Get FlashInfo Start
              12:05:01 499 <LAYER 2-1-6> INFO:FlashInfo: 0 0 0 0 0 4 4 0 28 0 1
              12:05:01 500 <Layer 2-1-6> Get FlashInfo Success
              12:05:01 502 <Layer 2-1-6> Prepare IDB Start
              12:05:01 503 <LAYER 2-1-6> INFO:CS(1) (0MB) (SAMSUNG)
              12:05:01 536 <LAYER 2-1-6> INFO:FindBackupBuffer-->No Found Tag
              12:05:01 537 <LAYER 2-1-6> INFO:FindBackupBuffer-->No Found Tag
              12:05:01 538 <LAYER 2-1-6> INFO:FindBackupBuffer-->No Found Tag
              12:05:01 539 <LAYER 2-1-6> INFO:FindBackupBuffer-->No Found Tag
              12:05:01 540 <LAYER 2-1-6> INFO:FindBackupBuffer-->No Found Tag
              12:05:01 540 <LAYER 2-1-6> ERROR:PrepareIDB-->Loader-->No Found IDB
              12:05:01 541 <Layer 2-1-6> Prepare IDB Fail
              12:05:01 544 **********Restore Done Success<0> Fail<1> Time<1045>ms**********
              As seen I tried both Upgrade and Restore functions.
              I am on Windows 7 (64bit). It did not find drivers so I had to install from 1.9a package. I tried 2 computers. Mine cable is rather good one (came with Samsung Galaxy S3).
              Is it completely dead or I can restore it still?'
              Thanks in advance.
                Mine brick is recovered
                OK, I figured it out. Mine PCB says CYXTECH V1_1. It is green colored PCB. I had to use CX919II firmware. I also learned that once it says IDB failed there is no way you can restore it unless you short circuit pins 6 an 7 and use RkBatchTool with firmware for CX919II. If you hold reset and connect it to USB the RkBatchTool would put green color on the box representing connected device. But if I do trick with pins 6 and 7 it would color it with deep blue. Then using Restore it would format the memory and upload firmware. After that I was able to use RkAndroidTool to upload custom ROM and let it run.
                Hope this may help anyone.
                Originally posted by MaksymK View Post
                Hi Team,
                Thanks in advance.
                  Is there a possibility to make this rom with the old wifi drivers MK802IV?
                    MK809III with RTL8188
                    Here is now the Custom Rom for all Versions off the MK809III,
                    This means it's run on Hardware Version 1,2,3.
                    This is a 720p Rom no 1080p at the Moment I need a Stable Kernel.
                    What is inside ?
                    A Complete Custom Rom for the MK809III without China Apps.
                    The Rom´s comes with a Patched Kernel for better Performance.
                    Also included are the newest WI-Fi Driver for Best performance.
                    *UPDATE*
                    What Software is included ?
                    Android 4.4 Fonts
                    Android 4.4 Boot Animation
                    SPMC Media Center (XMBC Fork)
                    Open Explorer
                    Netflix
                    SuperUser *fixed*
                    Terminal Emulator
                    Init.d Support
                    Added Support for the following:
                    NTFS
                    CIFS
                    XBOX Controller
                    Have Fun with my Updatet Rom for the MK809III.
                    After Flash on the First Run wait 3 Minutes before you Shutdown the Stick.
                    This is needed that all Software will be installed.
                    Download:
                    Kernel Links for different Kernels also include a 1008p Kernel.
                    The 1080p Kernel is kernel3.img.
                    Download:
                    Neomode
                    Finally decided to join after reading a bunch. I guess I got one of the older mk809iii's
                    Is there a build for this for the MK809III with the RTL8188 wifi chipset?
                    Hawkeye
                      Hawkeye
                      Have you looked at this?
                      Mk802IV Neomode 1.9a original rom 720p
                        Originally posted by Magnus33 View Post
                        Can you remind me which is the new WiFi and which is the old one ?
                          AP6210 is new.
                            Did you solve this issue?!
                            Originally posted by mymkv View Post
                            This rom works on MK809 IV just fine. WiFI works better than on any other roms. Bluetooth finally works too. Except one issue the video is statering. video playback is not smooth. I used 720p kernel. If Neo will fix this then this rom will be one of the best. Thank you for your efforts, Neomode.
                            I too have the MK809iv. It seems that it's so new that there is not much support for it. All I want is for it to play videos smoothly. I have the Mele F10 Pro air remote connected with the standard rom that it came with and when any video is playing it stutters until I move the mouse and then it plays smoothly, which is very odd!
                            I'm going to Flash to the 1.9a Rom and need to know which Kernal to use so that I can play the videos as well.
                            Did you find a solution at all?!
                            Cheers
                            Dan
                              All neomodes kernels are video fixed so if that's what you looking for just flash it with the one that the loader defaults to and enjoy.
                                I'm using Neomode 1.9a rom. Neomode kernel3 and CPU-Z gives clock range of 312Mhz-1.42Ghz on my MK809III. Before I was using kernel2 it gave me 1.2Ghz-1.42Ghz.
                                Running kernel3 in 1080p mode gives me lots of green pixels running through the picture. They go away when set mode to 720p.
                                HK1 Pro Plus
                                FlowFon F1
                                H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
                                MXQ Pro+
                                R-TVBOX Mini+
                                MK809III
