NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
    I"m back!!! 720p oced kernels!!
    So, i had some problems with the links before.
    These kernels are from neomode"s kernel in this forum oced with phanderson tool!!
    So the credits to them!!
    Enjoy!!
    https://www.mediafire.com/?3fg7abmzgj0b6ok 720p
    And i want to make a note!!
    TVDroid, this forum exist because we share everything, if we didn`t we would be closed!!
    So don`t ask me again for a private link and tell me that you don`t want me to share it with eveybody!!
    BE A TEAMPLAYER!
      Originally posted by nefas View Post
      Man, you're wrong. I made the same procedure several times and have no positive results. The cpu freq for all these krnls is limited to 1412 mhz. You could check it using cpu-z from playstore. Or please show us the prooflink.
      wbr, Nefas
      Nefas try the kernels and don't be an ''UNFAITHFULL THOMAS''!!!
        BE A TEAMPLAYER!
        You missunderstad me Bro, i ask private because i think its Beta or like this because you removed the Links first.
        But thanks for the Kernel, i test it now.
        EDIT: Your Kernel are not that what you tell... only 1200MHz for me ... And a Antutu makes reboots... totaly Crap.
        ... TVDroid
        > > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
          AW: NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
          The problem is the change something on the Mainboard and I don't find what it is. Revision 2 and 3 are different. I can make a Kernel that boot on Version 2 but not on Version 3. :banghead:
          #WTF
          Neomode
            The standart Kernel works perfect for me Neo, but it was nice with more than 1.42 GHz.
            But your ROM is GREAT thanks for that Dude !
            ... TVDroid
              Originally posted by theschnohr View Post
              you will neeed a diode so that power isn't drained - when you start the car.... place it before the capacitor - with a resistance - in front of it .
              Hi
              Thanks, just order a couple of **4700uf 16v capacitor** and as you said a handful of 12v diodes. So in the beginning of next week I will see if this is the solution!!
              ** I have read that it is ok with 16v, most readers prefers at least 20% higher volt on capacitor than you actually uses??**
              Basmand
                psu / USB ethernet adapter
                Originally posted by neomode View Post
                OK got you.
                I personally think the Problem is that the PSU has not enough Power for the Stick and the
                USB LAN Adapter.
                Can you try one with 3A ?
                Neomode
                Hi Neomod,
                Tried the 3A psu, did not give me stutter free streaming 1080p x264 content through Lan. So I guess it has to do something with my ky-rd9700 USB ethernet adapter. Read that it ain't a good one and that I have to buy a KY-AX88772ALF adapter for high speeds instead.
                Can someone conform if this is correct!
                And do I have to connect it through an USB 2.0 hub to my mk809iii?
                My Device: MK809III new Wifi Neomod Rom 2.0
                  Agreed...just run the kernel I posted and see for yourself. Why the hate???
                    Originally posted by suzook View Post
                    Why the hate???
                    I think its the Greece Situation right now, see what he posted a Note because a PN, he is crazy i think.
                    ... TVDroid
                      Let's keep this on topic and leave the flamewars to another forum site, guys. Mods and Santa are always watching....
                      Sent from my Nexus 7 using Tapatalk 4
                      Please post your h/w & s/w as signature to help community with troubleshooting problems.
                      Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
                      uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
                      iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
                      Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
                        on mk802iv
                        Enjoy!!
                        BE A TEAMPLAYER!
                        Just for a proof using 1800/stock/720 kernel!
ID:	431714Click image for larger version
ID:	431715Click image for larger version
ID:	431716Click image for larger version
ID:	431717Click image for larger version
                          I try your Kernel´s and all what i got is this ...
                          Or is that possible that the OC only works on a MK809 III ?? I have a Cozyswan S400, but the ROM from NEO runs great.
                          ... TVDroid
                            kernel kernel_j22_720p
                            hi there,
                            this rom runs pretty good, but wifi don´t work with my mk809iii. if i use the kernel kernel_j22_720p from this forum with this rom ther is a bootloop. is it possible to use the kernel_j22_720p with this rom, because it is the only kernel i found till yet, that makes wifi work with my stick. does anybody has got a solution for me?
                            chipset rk3188 AP6120 Cyxtech 909 V1.1
                            thanks
                              Originally posted by Phycopat View Post
                              Hello, first of all, NICE VERY NICE ROM here..!
                              Only got 2 problems, first the sound, HDMI PASSTHRUGH dosent stay on after reboot.
                              secound, i got a USB -> Lan adapter that makes my device freeze.
                              Link to ****: LAN Adapter
                              Seller thinks that the chipset used is: AX88179, AX88772A or SMSC7500 is any of these included in this ROM ?
                              Or do you have an other adapter that does give more than 7-8Mbit got 3 chep ones from china, but all low speed, this one gives me full speed but freeze or reboots my devices :/
                              - Thanks.
                              Anyone? :-)
                                This rom works on MK809 IV just fine. WiFI works better than on any other roms. Bluetooth finally works too. Except one issue the video is statering. video playback is not smooth. I used 720p kernel. If Neo will fix this then this rom will be one of the best. Thank you for your efforts, Neomode.
