is it possbile to somohow minimize the status bar automatically?
NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
Originally posted by dannyg View PostThe DL link at the begining of the post does not work!!
Is there another place to DL the file?HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by Magnus33 View Posthttp://www.w2comp.com/detail.asp?cat...4&pdtid=700202
There a few versions of that one but since your already at stock we can jump ahead
Download neomode rom from here and unzip to a folder.
Find the driver folder and the driver for your version of windows.
There should be three files write click on each tell you see install and then do so.
Now go insto the rkdeveloptool folder and double click on rkandroidtool
The tool should open
Plug the usb cable into the computer
Now the tricky part.. use a paper clip or the like to press the small buttion down in the hole on the side.
As your doing this plug the mini usb into the mini usb on the side next to the sdcard slot.
The tool should suddenly show found rockhip device and you can let go.
Click eraseIDB and when that done click run.
Watch the progress and you know when its done and after that plug in normally.
Dont worry about bricking since even a bad flash is fixable.
ok is this same process for the rk902 I see so many files and write click? 3 files ? What files and do I click erase idb on this model as we'll.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Ok opened the neomode rom flash tool
all the boxes selected except update.img
i selected the file from your file for each example loader i clicked where 3 dots on side of program and selected the loader from your file and same for each of the items checked from 1-7 i selected the kernel 1766 If i did that right then do i erase idb first? Then Click run? Its the first time ive used your flash tool so just wanted to get the process right is all and the box i am flashing is the rk902 model.
Thanks in Advance Neomode.
WezzyMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Wezzy
after this just click run and all parts of the firmware will be flashed
MK809III Bluetooth
Hello,
I have 809III with 1.9. I have problems with bluetooth.
I want to connect via bluetooth: keyboard, mouse and audio receiver. On the stock firmware I was able to set everything. Unfortunately, at 1.9 I have problems. Devices connect and disconnect for a while. After rebooting again, are in trouble. I don't know where is problem. MK see devices. But for "pairing" need time. But connection is unstable. The distance between the devices is about 20cm.
Can anyone say, where are some configuration files for bluetooth? Perhaps mode, the transmit power (?). Anything, I want to experiment with this device.
Compilation 1.9 is very good, but with Buletooth there is something wrong.
Compilation 1.9 is very good, but with Buletooth there is something wrong.HK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
I just got my ugoos mk809iv yesterday so im kinda new to this. But im trying to get it to play 1080p video's but al the roms i have tried so far have a stutter in the playback.
And when i try to use the neomode 1.9a rom it goes in to a bootloop. So far i have tried the defaul kernel, kernel 2 and 3 but they al give me the same result(bootloop). So im hopen someone here can give me some advies.
Originally posted by neomode View PostYour Device is a UM2 with external Antenna.
Neomode
There are currently 2342 users online. 0 members and 2342 guests.
