NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
R: NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
Originally posted by anselal View PostOn v1.9 I had no problems with wifi. On v1.9a the wifi disconnects after a while and there are no other kernels to flash like in v1.9. I dont want to go back to 1.9 cause I like the NTFS support.
Inviato dal mio GT-I9300 utilizzando Tapatalk
mk809iii
Originally posted by neomode View PostI had have no Problems for xbmc streaming. Please go to settings sound and change to HDMI passt rough.
Also the Audio Noise can come from the psu.
What kind of psu you have?
Neomode
but even with this psu didn't get any popping sounds on rom v1.8
thanks Neo
Styl3r
That should Work for you.
Neomode
Originally posted by neomode View PostThen Flash the Kernel from 1.9 to your Device you use before.
Neomode
Icannot use stick so.. Wherw I can find all kernel included to 1.9 rom? You have replaced link and I cannot find it!
boot loop
Hi neomode. Thanks for your work!
ROM 1.9a does not work with my MK809III
I flashed 3 times, but I see only 4 penguins, bootanimation start and reboot again... bootloop.
I tried different power adapters and cables for power - not helps.
I tried flash with sam321 kernel - still bootloop.
Works currect only stock firmware MK809III_root_AP6210_20131022.img but with frameskipping issue
Maybe other kernels from 1.9 can help? Please, upload it.
I dont know what vertion I have (where I can see it?). Pictures of my device.
[ATTACH=CONFIG]4323[/ATTACH][ATTACH=CONFIG]4324[/ATTACH]
did you erase idb before flash also did windows detected rockchip usb?
Download IDB Fail
I flashed my MK809III with "NeoMode CUSTOM ROM Version 1.9a MK809III AP6210 UPDATE". The flash went well, but xbmc is stuck, I disconnected the device, then nothing, the screen remains black tv.
I wanted to reflash it, but I always have this error "Download IDB Fail".
What to do, it is impossible to flash!
Thanks for help me.
There are currently 2083 users online. 0 members and 2083 guests.
