Inviato dal mio GT-I9300 utilizzando Tapatalk
NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
Originally posted by neomode View PostFirst did you Erase IDB?
Then what Kind of Power Supply you use?
Neomode
Yes i did erase idb and il's ok, start to run, start to download boot, download boot ok, start ti test device, device ok, start to download idb, Error: download IDB failed, ERROR: run failed.
I use usb cable connected to my pc (windows xp), drivers are installed.
I use RKDevelopTool_v1.37 loader V.1.2.
I tried to flash NHR 17, NHR18, NCR19mk809, NCR19amk809, but the same error "download IDB failed"
Thank you truing help me. I am sorry for my bad english.
AW: NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
Originally posted by apez View PostPlease neomode put online again 1.9 with kernels.. also in a gdrive link
He is fast enough :-D
Neomode
Originally posted by neomode View PostThe Links for different Kernels are in the first Post.
Neomode
Don't want to push on you, but do you think that there will be a kernel, that can solved my problem when disconnected from Pioneer APPRADIO TFT screen, stick close down or go to sleep???
Basmand
Can someone please point me in the right direction to make my mk809iii suitable for streaming full HD (mostly 1080p x264 mkv) content from my Windows 7 PC via lan.
I still have playback stutters.
What apps should I use?
Mxplayer seems to work but still have stutters, maybe other settings?
I'm on neomode 1.9a ROM
ThanxMy Device: MK809III new Wifi Neomod Rom 2.0
Originally posted by neomode View PostOK got you.
I personally think the Problem is that the PSU has not enough Power for the Stick and the
USB LAN Adapter.
Can you try one with 3A ?
Neomode
Btw any idea how to get rid of the google search bar on your latest 1.9a rom?My Device: MK809III new Wifi Neomod Rom 2.0
Neomode
The previous 1.9 ROM came with only 3 Kernels:
kernel, kernel1and kernel2
However you are now uploading 4 kernel files:
kernel, kernel1, kernel2 and kernel3
You mentioned that the 1080 is the kernel3, but could you please give us a description of the differences and functions of the other ones?... Is any of the 4 kernels overcloked?
Do you recommend me to use one of these 4 kernels with the 1.9 or 1.9a ROM, to have NTFS support, for my CX-919?
I am asking because it seems that the video playback is better with the 1.8 and 1.9 ROM, as some users already mentioned here.
USB LAN Adapter.
Neomode
Is this a 3A psu or what do you mean exactly?My Device: MK809III new Wifi Neomod Rom 2.0
Originally posted by ulises1954 View PostThanks Neomode for uploading again the 1.9 kernels...
The First is Stock DDR Clock and 1.6 Ghz
The Kernel one and two are DDR overclocked to 700 and 750.
The kernel 3 is a 1080 Kernel with 1.6 and DDR set to 650.
All Kernels have Video Fix.
The NTFS support is in the System not in the Kernel.
Neomode
There are currently 2190 users online. 2 members and 2188 guests.
