NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9a *UPDATE*
    Originally posted by magnetus View Post
    will this rom works with MK802IV?
    yes
      neomode
      sadly it doesn't work on J22
      with your kernels it boots ok but wifi and bt doesn't work
      with any of my kernel it doesn't boot...some starts to load and die when it should open desktop, other just have no picture...
      what github so you use for kernel building?
      or can you make a kernel with J22 specs that i wrote in other forum....?
      with you kernel it feels fast....but useless without wifi (could live without bt thou)
        This thread is for MK809III only.
        The thread for J22 is the Neomode Hybrid Rom Thread.
        I have splittet the MK809III from the Neomode Hybrid Rom Thread because the MK809III UserĀ“s had
        Trouble with it.
        Neomode
          Trouble with it.
          Neomode
          HI Neomode, could you please help me?
          If not I must come back to recovery pack of MK809III there's some reason why if I use ROM_Flash_Tool_137.exe with 1 image all is ok , and if I use RKBatchTool.exe with various file I have always black screen into tv?
          Many thanks for your answer.
            Old wifi?
            Hy neomode
            For MK809 III - old wifi, this is not working, right?
            When u update rom for old wifi
            Thank u for hard working !
              AW: NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9
              I know I must update the Old ones.
              Will do my best but without Time line.
              Now first the X7 Mini then the others.
              Neomode
                Hi neo,
                the rom works great on my 809III on 720p, even when i reboot this time!
                i used kernel.img (which is default) works ok when i set it to 720p but when i change video overlay to 1 ( than reboot) i set the hdmi output to 1080p then i get a distorted image on my tv.
                is this due to the kernel.img? if so, which of the 3 should i use?
                  Try with Kernel 3 please.
                  This should the best for Fullhd.
                  Neomode
                    Re: NEOMODE CUSTOM ROM MK809III AP6210 Version 1.9
                    This is what i get with kernel kernel1 and kernel2.img when i set the hdmi output to 1080
                    after switching kernels i have lost root and don't know how to get it back
                      CloudNetGO CR9S
                      Thank you neomode for this wonderful ROM! It seems to work for my CloudnetGO CR9S (BT & WiFi work, but I haven't tried changing the build.prop for 1080p yet). Is there a way to make it show up in the Google Play Store as a Galaxy S3?
                        Originally posted by anselal View Post
                        Thank you very much for this ROM. I just downloaded it and will try it out later at home. I have a mk809iii with AP6210 and the wifi was very weak. Version 1.7 of this rom worked very good for me. Version 1.8 not so well. I hope version 1.9 will work as good as 1.7.
                        you will have my feedback as soon as I install the ROM at home.
                        what about kernel1.img ??
                        Just installed new version and it works like a charm. Super fast, wifi is working great. I did't check with full-hd but don't need it right now. Also did't check for root. XBMC is working normal
                          This version for Old wifi
                          Ok, I download this firmware and the bluetooth and wifi does work, so I now today I have a old wifi, do you have another great firmware with old wifi?
                            Yes i have go over here:
                            Neomode
                              Finally I've installed 1.9 rom and all perfect! !
                              Only 2 things:
                              1. To power up stick I must use otg port if i connect dcin black screen, it's normal?
                              2. I can't read a 2 tb external unit auto powered. With a flash pen of 32 gb no problem.
                              Could you confirm that?
                              Many thanks
                              Inviato dal mio GT-I9300 utilizzando Tapatalk
                                Only 2 things:
                                Many thanks
                                Hello
                                To question one I must test it by my self
                                Will report back.
                                Question Two
                                What File Format Your Harddrive has?
                                NTFS can be a Problem
                                Where become the Device his power?
                                Neomode
