Sorry Guys, I left my cable in the office, so cannot reflash to 1.5 today...aarrgghh. Iam also off on Holiday next week so may not get time now unill the New Year. I can only suggest that those who need the OpenVPN do so on 1.4 with the tun.ko installer. I have not needed the dreaded reset button on this ROM so have only needed to run the installer once. Cheers for now, Colin.
Pipo M9 Pro - Finless 1.5 ROM
OOPS No Cable !
Thanks for this rom :-)
For me its the best rom regarding speed and smoothness, but I'm getting more wifi disconnects than with any other rom I've tried. Is there any way to use this rom without your wifi modifications?
Had the same problem with finless 1.4.
It would be great if theres a way to use this rom with stock wifi settings, as I'm getting zero freezes with this rom till now which is a HUGE improvement.
The following does not help with disconnects, but for me it totally cured the slow connection problem:
-Use a simple SSID with no more than 8 letters
-Password also only 8 letters
-Wifi channel must be between 3 and 8
With this settings the speed went up from 2mbit/s to 12mbit/s.
Does anybody else have the wifi disconnects every 3-5 minutes with this rom?
I was already thinking that something inside the tablet broke because they occured so often. I flashed the new Kasty Rom 3 hours ago and did not have a single disconnect since then :-) With finless 1.5 i would've gotten at least 25 disconnects in this time. Really weird.
On the other hand I'm already missing the smoothness of finless.
edit: the 3 hours without disconnect were pure luck, I've been gettin almost as many reboots with kastys rom after some hours of use.
Trying madsega's fix right now :-)Last edited by dothedew; 19 December 2013, 01:32.
Originally posted by PipoM9Pro View PostHey Bob ,
Are you going to rehash 1.5?
I was going to load it up but I am unsure if you are repackaging 1.5?
Agaam50
I must say that the suport of Riley was better, on this forum.
sorry Finless
tun.ko module
Originally posted by Finless View PostOK before I cook another ROM to fix VPN I would like it if you could test these modules in my 1.5 ROM.
Download this zip
Unzip these 2 modules (tun.ko and md4.ko).
Put them on sdcard
Install ES File Explorer
Turn on root in ES File Explorer
Make sure to also mount /system as RW as by default it is RO and you wont be able to copy the files.
Copy these 2 files to /system/lib/modules replacing the ones that are in there.
Make sure ES File Explorer confirms the copy and does not give an error.
Reboot
Now install Android Terminal Emulator.
Run it and at the command line type lsmod
It should list all modules installed into the kernel and tun and md4 should be in the list.
Now try your VPN.
Thanks,
ps - does anyone else have a problem typing in this box? itseems tohave goneverry laggy over the past week?? (hence the lack of spaces in that sentence!)
OK so Randy's ROMs inject tun.ko and md4.ko. It's easy to see in init.rc
I bet you folks did not know that?
So I did the same thing in my ROM but obviously I used other files KO files that may not work. The files I gave for my test request were directly from Randy's ROM. So it should work. If not then the stock ROM made from this and Randy's ROM made from this same stock ROM should have the same problems.
So something else is going on here!
.ko's
Originally posted by Finless View PostOK so Randy's ROMs inject tun.ko and md4.ko. It's easy to see in init.rc
Edit:
So something very fishy is going on here Bob - there are NO tun.ko modules on my Samsung Note yet the same openvpn configuration file works on both devices? I checked terminal emulator and no tun.ko or mk4.ko running and es cannot find any either? I am tpted to go back to RROM2.0testor 2.1 to see what happens there now, but maybe no need ? please advise have some time right now I can do more tests.
Modules can be built in the kernel and if they are will not show up with a lsmod command.
Only modules not in the kernel that are injected by the insmod command in init.rc will show up with a lsmod command.
Nothing fishy....
Originally posted by Finless View PostModules can be built in the kernel and if they are will not show up with a lsmod command.
Nothing fishy....
Re: NEW - Pipo M9 Pro - Finless 1.5 ROM
Originally posted by Finless View PostNot until someone does the test that I asked for tun.ko.
OK well maybe I will be happy with my ROM myself and let it ride and enjoy my M9 myself. I have plenty of other ROMs to do with plenty of people asking. Back to TV sticks then.....
Thanks a lot to you and also to Randy.
Enviado desde mi GT-I9300 usando Tapatalk 4
Respect?
See ? - first post and all he/she does is ask how to change something - no thanks, no explanation no information - General Public !!
So, in answer to your question datmbm: compare the two files build.orig and build.prop in the system folder - note the lines for wifi and edit the ones in build.prop to match those in build.orig - reboot and you will have the original wifi settings that Pipo created. Why not simply use the stock ROM ?
There are currently 1967 users online. 1 members and 1966 guests.
