With new Leolas Rom plus set sleep at 30 seconds...Turned off bluetooth and turned off location finder and it solved battery issue longevity issue for me. Just and FYI
Pipo M9 Pro - Finless 1.5 ROM
Originally posted by Playonlomer View PostWith new Leolas Rom plus set sleep at 30 seconds...Turned off bluetooth and turned off location finder and it solved battery issue longevity issue for me. Just and FYI
OMG OMG OMGPipo released the 4.4.2 KITKAT for wifi version!
link: http://aw2tznbg7w.l45.yunpan.cn/lk/QDtfY2SJiB6Ma
"M9pro Chinese wifi version of the firmware upgrade Upgrade to Android 4.4.2 system This beta version of Android 4.4, only for lovers prerelease experience, the average user does not recommend upgrading"
Originally posted by asoft4dex View PostOMG OMG OMGPipo released the 4.4.2 KITKAT for wifi version!
Waiting to Riley..
Thanks for the link!!!!!!Randy
WiFi Only
Hey All, I just asked Anna at Pipo if we can use this new KitKat Firmware with our 3G tablets and she said wait for the release of 3G version. I also asked about the battery drain issue, so there could possibly be separate releases this time to address the battery drain. She did not (of course) actually answer my questions, she just told me to wait! With China not takng any holiday over the Chistmas period we may not have to wait too long.
Originally posted by rrileypm View PostThe good news is that if you successfully flashed the Kasty ROM, you won't have any trouble flashing this one. The Finless ROM has some more advanced improvements, so it's worth a try.
Check out this thread for details on how to flash a ROM with the Finless Flash Tool:
This is the guide I include in all of my Pipo ROM's.
I have now been able to get Flashed with Finess Rom 1.5 . I was finally able to get past a problem, which I been having from the start of my flashing experience with the m9pro. When I would run the "ROM_Flash_Tool_137.exe" on my Windows 7 64 bit PC --
1) I would see a message saying "Found RKAndroid Mass Storage Usb". (good, no problem)
2) But when I pushed the "Reboot to Flash Mode" button -- I would get a dialog box message, telling me that "Device can not do switch, because of no drive."
I was able to get into Flash Mode -- by executing the "RKBatchTool.exe" . Finless has this in his group of files in the (not surprisingly) folder: alternate_reboot_to_flash_tool .. I had also used a slightly newer version of this program from some of my other Pipo flashing experiences. Users are encouraged to read documentation on this Tool, before using it. You might run the Risk of Bricking your device if you hit the wrong buttons. I pushed the "Switch" button, my m9pro went dark.
I went back to the ROM_Flash_Tool_137.exe program windows -- which now showed the message "Found RKAndroid Loader Rock Usb" .. I was then able to proceed, with the erasing the NAND, and onward to the rest of the Flash Process. It all worked Great! Thanks all for your help!
Originally posted by gogojoe View PostThat is a Wonderful - First Time User's Guide. I highly recommend anyone who hasn't read it, to read it, regardless of whatever Rom they are considering flashing.
He's right. Both Finless and I include the RKBatchTool as an alternate way to reboot to flash mode. Our ROM's can't be flashed with the Batch Tool, but it does come in handy when you can't get into flash mode any other way.
Then, if you need to flash a stock firmware for some reason, you already have the tool to use.Randy
Originally posted by ludoke View PostThese are 2 different tools!!! You have to use te tool witch comes with the rom.
That put my m9pro into the correct mode -- showing the message: Found RKAndroid Loader Rock Usb.
I couldn't find any other way to get into the proper Flash mode so that I could proceed with the Finless Flash program.
Everything else that I did was initiated with the Finless flash tool/program ROM_Flash_Tool_137.exe. I was then able to proceed, with the erasing the NAND, and onward to the rest of the Flash Process (using the ROM_Flash_Tool_137.exe progam interface).
Hi
I have a Ntech RX5QC also with RK3188 chip. This one: http://www.ntech.pt/index.php/tablet...dados-tecnicos
Will this version of 4.4.2 will work on it?
About the software to update what should I use?
Will RKBatchTool 1.6 flash it?
Another thing: can get to install the drivers. All the files/drivers I get, doesn't work...
ThanksLast edited by rop12770; 28 December 2013, 20:55.
Originally posted by Finless View PostHi folks!
Pipo released a new ROM shortly after I did my first 1.4 ROM.
While making this 1.5 ROM based on the new Pipo release, I did find a problem with my 1.4 ROM and battery savings for wifi tablets. This is now fixed in my 1.5 ROM.
Additionally I added by request VPN support (tun.ko and md4.ko) at boot!
Enjoy
__________________________________
Features and release notes for my 1.5 ROM:
Enjoy folks!
I've installed the 1.5 ROM on a PiPo M9 Pro 3G , and It seems there is no cifs.ko module ? am I wrong or did you intentionnally omit it ? is there a way to have a cifs-enabled ROM for PiPo M9 Pro 3G ? (I really need this module for my daily tasks with this device)
Thanks for any information you would have .
Regards,
Sidh
There are currently 1985 users online. 0 members and 1985 guests.
