How should I do it?
Pipo M9 Pro - Finless 1.5 ROM
Originally posted by nAFaNyA View PostYes, boot animation + boot logo
For boot animation can I delete bootanimation.zip in system/media, then get a stock boot animation, right?
And where is the boot logo?
Originally posted by ludoke View PostYes,have a number also,when you insert a sim from diffrent carrier the number changes also.
I must assume that there's not a list with the correspondence between numbers and names of providers.
Sleep 20 hours battery 80 percent
Set ROm 1.5 - clean and tablet loaded to 100 percent.
Disconnect your modem and wireless communications.
I did not set any application and even did a Google account - nothing.
Tablet and slept 22 hours, I woke him up - Battery showed 20 percent.
Why this firmware ate 80 percent battery?
Originally posted by belier View PostI've seen that the list of providers is also a list of numbers.
I've opened /system/etc/spn-conf.xml file and there's the correspondence between the number and my provider.
Don't know why it's not used.
Originally posted by venso View PostSet ROm 1.5 - clean and tablet loaded to 100 percent.
It,s surtenly ,the issue is not the rom,i have tried differend roms and 1.5 is the most battery frendly in my opinion.
Battery life sucked and NO ROM is going to fix that.
You will know wifi is not right when you connect to your router and a few minutes later Android wifi connection reports a connect rate of 5mbps or less. Then disconnects and reconnects all the time. You know this happens when downloading.
When wifi is not working well...... it SUCKS battery!
Now in my ROM I tuned wifi and also tuned how often it looks for new APs. This helps with battery life!
But if your wifi antenna is JACKED... nothing a ROM can do to fix that.
I am sorry of you have this probem. Your only choice is:
1) Return your tablet and get a new one.
2) Take it apart and fix the wifi solder problem.
ludoke, thank you... You are seeing what I am getting too. Nice isn't it? You obviously have no hardware issues
FYI I made a custom ROM for me that kills GPS totally. I don't use GPS. My tablet can be in sleep for 7 days and when I hit the button it still has like 60% battery after 7 days!
NO! I wont share this ROM right now as it causes Google location and play services issues. But later when I get some time I will try to fix that. But for what I use this tablet for... AWESOME
It actually works better power wise than my Wife's $900 Ipad!!!!!
Originally posted by Finless View PostLook... I had this same battery SUCK problem when my Wifi antenna was freaking shorted!
I thank you for your great work on the creation of good firmware!
I'm sure - it's the Problem of Chinese iron.
I was just unlucky with the tablet ...
Wireless network works for me is good - there is always a relationship and I do not know what is broken.
Once again - Accept my thanks for your fantastic work - I wish you good luck and prosperity!
First of all, thanks for your work with this ROM. It works great on my M9 Pro 3G.
And now, two questions, one general, and the other about your ROM.
- How can I know if my M9 has a faulty Wifi?
- Why the spn-conf.xml is ignored? On the list of 3G providers there are only numbers.
Thanks in advance.
Thanks in advance.
There are currently 2967 users online. 1 members and 2966 guests.
