Thanks for your time and efforts.
And two questions about the installing process:
Pressing Power + Esc buttons should put tablet in Loader Mode? I wasn't able.
I've had to press reset button while holding Esc.
In the Readme.txt you say "2) Connected the supplied USB cable from the device OTG port (far right port) to your PC."
It's a bit confusing. I think that OTG port is the one labeled Host, and the USB cable must be connected to the port labeled USB.
